 Post subject: Verbatim 32 GB red pinstriped usb stick write protection
PostPosted: January 11th, 2017, 9:58
Just got a stick with this problem - started all by itself. Media not accessible, shows up as raw, when I insert it I get the message that it needs to be formatted. But that's not possible, and I can't repartition it either. Recovery and formating software doesn't work. Also tried making a registry entry to turn off write protection, and that did nothing.
Not sure what else to tell you. Just ask if you need more info.
I btw also tried several different programs like GetDataBack, Minitool etc etc to recover data, but no partition is found, nor is any data.
 Post subject: Re: Verbatim 32 GB red pinstriped usb stick write protection
PostPosted: January 12th, 2017, 10:14
a Photo Would Help ?
PostPosted: January 12th, 2017, 11:19
Memory has degraded, bin it if you don't need the data
I'm assuming you don't need the data as you've been trying to format it!
If you do need the data, it's a "chip off" recovery which needs pro equipment and skills, not DIY :-(
PostPosted: January 12th, 2017, 19:27
A photo of the stick?
I actually need the data.. How do you know for sure it's degraded? Cant it be that the controller got messed up by removing the stick from the computer by just pulling it out in the middle of a file transfer, for example?
PostPosted: January 12th, 2017, 22:04
larsjorgen wrote:
shows up as raw
But not its full capacity (I guess) ?!
Chip off or bin it as pcimage suggested
PostPosted: January 13th, 2017, 12:23
jermy wrote:
larsjorgen wrote:
shows up as raw
Yes, full capacity.
PostPosted: January 14th, 2017, 19:42
Check in a HEX editor if there is something on it (except for 0x00)
PostPosted: January 16th, 2017, 10:02
How can I do that if I'm not able to access the device?
Users browsing this forum: No registered users and 14 guests
