 Post subject: Seagate 7200.12 1TB ST31000524AS
PostPosted: January 16th, 2017, 19:33
I've got a drive I really need help with
F/W is JC4A
The drive is no longer detectable by bios/os after a normal shut down of a PC. Nothing unusual happened to the PC it just stopped being detectable any more.
I do have a USB RS232 to UART interface that has 5V and 3.3V TTL that I've still keep since I fixed my 7200.11.
After connecting it to the 7200.12 im getting message from the drive but CTRL+z doesnt work. I've seen somewhere else on this forum that its because the drive uses 1.8V TTL?
ok, but back to the case
this is what is being displayed when powering on the drive with RS232 connected:
I also got a donor board and I could swap flash chip to new board but i think it wont help so would like to confirm before wasting time on de-soldering and soldering it again
can anyone confirm that the drive can or cannot be fixed using a properly working RS232 adapter and/or new donor board?
thanks
kind regards
Sebastian
 Post subject: Re: Seagate 7200.12 1TB ST31000524AS
PostPosted: January 17th, 2017, 15:25
I've been told that this cant be fixed using just the serial interface and donor board
so my question is:
Any pros or people with adequate equipment from UK or Ireland able to fix this for money?
please PM me if interested
PostPosted: January 17th, 2017, 15:48
Try Andy at databusters in Glasgow :-)
PostPosted: January 17th, 2017, 15:51
I second that, Andy will sort you out. www.datarecovery.co.uk
Data Recovery Cape Town
PostPosted: January 17th, 2017, 16:24
Considering he's prepared to pay for recovery, I'd suggest he take it to a pro instead of fiddling himself.
PostPosted: January 17th, 2017, 16:33
well I like DIY and as long as I can do something without risking it too much I'm happy to do it and learn something in the process maybe
I said I'm willing to pay as I've been told by one company I contacted that it cant be done that way
just have it connected and accessing via terminal again, I'll wait >=6min this time and then try ctrl+z
is that drive ok with 3.3V TTL?
PostPosted: January 17th, 2017, 16:51
There's a reason your drive has an error like this, there is some form of hardware problem that has caused this.
You mentioned the adapter you have from the 7200.11 SD15 fix. That was a fix to a bug, where as this is a symptom of a hardware problem. Even if you managed to 'resolve' the symptom you still have an underlying problem that's most likely going to require a hardware imager, maybe even a headswap if you have a failing head in there.
The 7200.11 fix and this problem are vastly different. Personally I wouldn't recommend fiddling with firmware commands just because you can read the terminal output.
Either way, if you value the data and want to spend some money recovering it then Andy will assist you. If you want to go the DIY route then good luck.
PostPosted: January 17th, 2017, 17:51
i have gained console access after very long wait and im now at F3 T> will try /7m100 as suggested
PostPosted: January 17th, 2017, 17:54
typing /7m100 in F3 T> resulted in instant command execution i didnt need to wait for anything to happen and now im on F3 7>
ill do a power cycle now and check if the drive is accessible
PostPosted: January 17th, 2017, 17:58
nah it didnt helped its still the same:
here is a terminal log for the operation
Rst 0x20M
RW: Disc Ctlr Initialization Completed.
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
No HOST FIS-ReadyStatusFlags 2002A1A5
ASCII Diag mode
F3 T>/7m100
F3 7>
Rst 0x20M
PostPosted: January 17th, 2017, 18:15
Thank you Spildit for helping me trying the DIY approach
I'll contact Andy
PostPosted: January 17th, 2017, 20:55
no luck, still not detectable in OS
you can see diagnostic terminal + dmesg on the screenshot above
i guess that means Andy is my only hope now
the data isnt really of top importance but it is important
thanks again Spildit
PostPosted: January 28th, 2017, 8:14
just wanted to update on this one
Andy did a great job of recovering the data quickly and in very good price
Thanks to pcimage and Nick_CT for recommending him
and thanks again to Spildit for his attempt to help me with that disk
kind regards
Sebastian
Users browsing this forum: Doomer and 172 guests
