 Post subject: Maxtor 6Y080M0 FW+Loader Required
PostPosted: March 16th, 2017, 14:47
Got a very old drive in hand.
6Y080M0-YAR511W0
Need FW+Loader
If anyone have this one please share
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Maxtor 6Y080M0 FW+Loader Required
PostPosted: March 16th, 2017, 14:59
Is this OK?
910.zip [606.92 KiB]
Downloaded 1069 times
PostPosted: March 16th, 2017, 15:05
Thanks, but it's incomplete.
Modules are missing, Loaders (Boot.com, boot.ram) are missing as well.
__________
THANK YOU
SHAHI
PostPosted: March 16th, 2017, 16:05
For dealing Maxtor Drive, I've SD Doctor also MRT (MRT could be buggy, I found a Loader but it's not working, most of the functions of MRT Maxtor looks like dead)
It has been several years I worked with Maxtor HDD, yes, in SD Doctor, the loader is Boot.cod and boot.ram...
@spildit, fzabkar shared the resouces from SD Doctor! and things are missing as stated!
By SD Doctor, things are like the following picture
__________
THANK YOU
SHAHI
PostPosted: March 16th, 2017, 16:20
FWIW, I have 6Y080M0-YAR51HW0.
PostPosted: March 16th, 2017, 16:35
Hi...
Try this ...(only modules)
Maxtor-Calypso-Maxtor 6Y080M0-YAR511W0.zip [584.23 KiB]
Downloaded 970 times
PostPosted: March 16th, 2017, 16:39
Or this....(RAm+modules)
Maxtor-Calypso-Maxtor 6Y080M0-YAR511W0 2.rar [1.09 MiB]
Downloaded 921 times
PostPosted: March 16th, 2017, 16:43
Spildit wrote:
On HRT 3.0 and 5.0 MAXTOR "Loader" it's just the totality of CPs that you send to the drive. There are modules and CPs. CPs can be loaded in reverse as well or you can select what to load.
The "1.GRP" and "7.GRP" files in my first resource consist of CP0 to CP22. I can extract them for you if necessary. (The 2 GRP files are identical, BTW)
PostPosted: March 16th, 2017, 16:46
@jackass, its not helpful yet until I get loader or boot.cod and. ram
I found some fw in hddsurgery site, but didn't work with mrt. as said, seems the mrt is bugy, and thee hdd with SATA interface by the way
@fzabkar, you can share whatever you have, can try at least
and it would be great if its possible to extract /convert into boot.cod and. ram
__________
THANK YOU
SHAHI
PostPosted: March 16th, 2017, 17:11
The loader I found in hddsurgery in pc3k format, in mrt it can be used as I see it has the function. but it fails, the reason can be either the loader is not compatible or mrt is buggy.
in sd, it gets grp as well which are in total 9 what I can remember. the cp you are referring I see it 22pcs of files. if grp contains the boot n ram. so which numbers? so that can be converted straight by just renaming the extension (not sure. if its gonna work or not)
__________
THANK YOU
SHAHI
PostPosted: March 16th, 2017, 17:12
Are these of any use?
Y23.zip [2.38 MiB]
Downloaded 809 times
Y22.zip [2.14 MiB]
Downloaded 785 times
PostPosted: March 16th, 2017, 17:13
Could we see an example of each loader?
PostPosted: March 16th, 2017, 17:22
Thanks, hopefully things can be helpful. Will try with SD Doctor tomorrow and update you here
__________
THANK YOU
SHAHI
PostPosted: March 16th, 2017, 18:37
It looks like the HRT loader prefixes each CP with its size in bytes, plus some minor header stuff. It should be easy to convert between one tool and another.
PostPosted: March 16th, 2017, 19:00
Here are the CPs from the "910.zip" resource dump.
CPs.rar [244.84 KiB]
Downloaded 883 times
PostPosted: March 16th, 2017, 19:41
The BOOT_nnnn.COD file appears to have the following format (YAR51HW0 example):
00000 - 001FF  header
00200 - 201FF  CP0x00
20200 - 203FF  CP list (IDs and sizes)
20400 - 243FF  CP0x03
24400 - 283FF  CP0x04
90400 - 943FF  CP0x1F
The "nnnn" characters in the filename correspond to the checksum word at the end of CP00. Each CP also contains this word at byte offset 0x04.
header:
00000000  01 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00
                                  size of CP00 = 0x20000
00000010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000001F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CP list:
00020200  01 03 00 00 00 00 00 00 00 40 00 00 00 00 00 00
             CP ID                size in bytes = 0x4000
00020210  01 04 00 00 00 00 00 00 00 40 00 00 00 00 00 00
00020220  01 05 00 00 00 00 00 00 00 40 00 00 00 00 00 00
000203B0  01 1E 00 00 00 00 00 00 00 40 00 00 00 00 00 00
000203C0  01 1F 00 00 00 00 00 00 00 40 00 00 00 00 00 00
000203D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000203E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000203F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
end of CP00:
000201F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF CD 6C
                                                 checksum
PostPosted: March 16th, 2017, 19:46
I goofed with CP0x00.bin in my earlier RAR.
Here is the correct one.
CP0x00.rar [70.78 KiB]
Downloaded 688 times
PostPosted: March 17th, 2017, 14:31
Attached is a PC3000 loader for the YAR511W0/6Y080M0 drive.
One loader contains CP3 - CP1F, the other includes CPs 3-22.
6Y080M0_YAR511W0_LDR.rar [431.73 KiB]
Downloaded 622 times
Users browsing this forum: Majestic-12 [Bot] and 33 guests
