 Post subject: WDC WD10EZEX-00RKKA0
PostPosted: March 16th, 2017, 9:36
Hello!
the drive in topic shows all sectors ABRT.
heads, modules are OK and PCB changed with no luck.
Any suggestions ?
Thanks in advance.
 Post subject: Re: WDC WD10EZEX-00RKKA0
PostPosted: March 16th, 2017, 13:17
If you have a professional tool like PC-3000 try running a heads test. It could be that one of the heads has failed and will need to be disabled. Even if a head is just unable to write it may act like that.
PostPosted: March 16th, 2017, 14:01
Thanks for replying.
I have tested the heads with MRT and it said it's OK.
Maybe replacing the heads will short the problem if it head/s or something else.
Thank you.
PostPosted: March 16th, 2017, 14:45
write/edit anything like: 00 to any of the modules, refresh and see/ power off/on see if the value remains same or modified as acted!
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: March 16th, 2017, 22:17
Tested and write succeed.
Thanks for reply.
PostPosted: March 17th, 2017, 4:54
Try changing the head map in RAM to "0000" and soft reset, see if you can read sector 0
PostPosted: March 17th, 2017, 17:44
Thank you Mr. Sean. I will try this at the office tomorrow and post the results.
PostPosted: March 20th, 2017, 9:26
Unfortunately, no luck.
Any suggestions ?
Thanks in advance.
PostPosted: March 22nd, 2017, 4:22
encounter the same situation,
and translator regeneration doesn't work
PostPosted: March 22nd, 2017, 23:56
had successfully recoveryed.
Some Modules were bad,rewrite them with identical version.
Users browsing this forum: Google [Bot], hwfix888 and 74 guests
