 Post subject: Looking for WD donor
PostPosted: March 22nd, 2017, 21:50
Hello!
Need donor for disk WD 1600BEVT
(need heads)
info:
model WD1600BEVT-75ZCT1
S/N WD-WXE608H...
DCM: HHCVJBBB
Date: 22 Jun 2008
Product of Thailand
 Post subject: Re: Looking for WD donor
PostPosted: March 22nd, 2017, 21:52
Have you checked eBay or Saturn?
PostPosted: March 23rd, 2017, 3:41
Will almost certainly have one, but I'm afraid we don't ship to Mars.
If you can accept delivery to an address on planet Earth then we can try and help.
PostPosted: March 23rd, 2017, 4:01
:lol:
PostPosted: March 23rd, 2017, 14:50
eBay, Amazon, donordrives... google, yandex, (even tried baidu) and all local forum and sites :(.
At this time of the year Saturn is in a bad position so it's easier to carry out the delivery from Earth.
As far as I understand, it's hard to find the right disk, because it's a rare model or exactly a rare head unit.
Damn earthlings! :twisted:
(sorry it's was autocomplete for forms and i was not very attentive)
Need ship to Russia.
PostPosted: March 24th, 2017, 3:21
http://www.ebay.co.uk/itm/162437572569
PostPosted: March 25th, 2017, 1:10
northwind, thanks but I already saw this disk and this is wrong model.
Maybe I'm wrong but explained to me, I was able to understand what exactly in the discs of this "series" the heads block is different from other models.
PostPosted: March 25th, 2017, 2:43
It's same model and it should be compatible with your drive.
PostPosted: March 25th, 2017, 18:36
northwind, Are you absolutely sure? Excuse me for distrust but we already bought two discs which differed only in several simbols and both were unsuitable :(.
I was explained that even a serial number is not important as DCM which should completely identical, otherwise there will be other heads.
PostPosted: March 25th, 2017, 18:41
FWIW ...
http://forum.acelaboratory.com/viewtopic.php?t=9234&p=32654#p32654
PostPosted: March 25th, 2017, 20:08
Denali are one of the most friendly WD drives in head/s replacement. :)
PostPosted: March 27th, 2017, 15:51
Where are you from Russia?
This is not a rare disk :shock:
http://forum.acelab.ru/viewforum.php?f=59
https://wdmarvel.com/forum/ru/viewforum.php?f=9
Contact the participant of this conference-Tomset (Moscow)
PostPosted: March 27th, 2017, 17:35
hedgehog wrote:
Hello!
(need heads)
I beleive you are not a professional. So do you understand what will you do with this donor drive? If data is valuable for you, may be better to bring this drive to professional company? I can find nearest location to you and ask my colleagues to make discount for you, just tell me in which city are you.
PostPosted: April 1st, 2017, 3:15
Thank you all!
The problem was not solved, but information recovery was too expensive for the customer and he preferred to refuse repair.
