 Post subject: Western Digital Caviar SE WD1600JS-56HMHB1 i need rom
PostPosted: April 13th, 2017, 8:52
Hi All.
I need rom file of eeprom of this WD disk:
WD1600JS-56MHB1
S/N: WCANM8815227
MDL: WD1600JS-56MHB1
DATE: 18 DEC 2006
DCM: DBBHNT2CHN
WD P/N: WD1600JS-56MHB1
Product of Thailand.
Original PCB burnt and rom IC is out ;-(
Please help!
 Post subject: Re: Western Digital Caviar SE WD1600JS-56HMHB1 i need rom
PostPosted: April 13th, 2017, 11:02
This is Hawk drive
you have many options here: http://files.hddguru.com/download/PC-30 ... lity/Hawk/
good luck
PostPosted: April 13th, 2017, 11:47
Thanks for answer, i checked all roms included in link but no results. With some roms drive is identified with "hawk", other drive clicking with no ident, and other with blank id, fw and 0 lba.
PostPosted: April 13th, 2017, 12:11
You saying that U12 is dead? you will need to rebuild ROM from SA on this drive - Can you post a picture please
PostPosted: April 13th, 2017, 12:34
I never knew you could build a ROM from SA on an older Marvel drive. I'm interested in seeing your method.
PostPosted: April 13th, 2017, 13:06
Yes, i can. But a picture of what? I have a required tools and skills. Eeprom from original pcb is dead. I replace and use the correct version of pcb and use roms from this site with no results. :-(
PostPosted: April 13th, 2017, 14:51
Maybe preamp is gone too
PostPosted: April 13th, 2017, 17:25
A picture of the PCB would enable us to assess the nature of the damage, which may in turn help to assess the likelihood of preamp failure.
cron
