 Post subject: WD20PURX using compatibile PCB to 2060 771945-002 rev A
PostPosted: April 13th, 2017, 16:14
Hello
I have disk WD20PURX with damaged PCB. So PCB was cut with something sharp and many tracks are damaged. Number PCB is 2060 771945-002 rev A.Because at the moment I don't have the same PCB is it possible using another PCB? Could help me what PCB I can use? I attached some photos disk and PCB.
thanks
 Post subject: Re: WD20PURX using compatibile PCB to 2060 771945-002 rev A
PostPosted: April 13th, 2017, 16:25
Easy! Just get PCB with same P/N and switch U12 chip.
PostPosted: April 13th, 2017, 16:28
Yes, but I don't have another PCB 2060 771945-002 rev A!
PostPosted: April 13th, 2017, 17:14
771945 is really a very common PCB, its been used on a wide variety of drives
PostPosted: April 13th, 2017, 17:27
yep, in WD Red for example..
some good ones at Ebay: http://www.ebay.com/sch/i.html?_from=R4 ... 02&_sop=15
http://www.rescue-it.se
