 Post subject: Data Recovery Issue
PostPosted: April 18th, 2017, 0:42
Hi I have a dead hard drive, and i need the data off of it.
Here is the story…
i bought a G-Technology 4TB G-DRIVE Thunderbolt USB 3.0 Hard Drive
It stoped working randomly. :oops: I would turn the unit on and no fan, no power up… nothing…
So i opened it up. Inside was a
HGST Ultrastar 7K6000 4 TB Internal HD ‑ SATA ‑ 4" ‑ 7,200
I bought the OWC Drive Dock.
Now when i try to mount that the following happens.
"The Disk you inserted was not readable by this computer"
When i go to disk utility I don’t see my mounted drive… only a config media listed under external. with a capacity of only 104.9 MB
First Aid Passes, but doesn’t do anything.
I can’t mount, or anything.
I’ve downloaded Disk Warrior and other disk restore programs… all with 0 success.
What is my next step?
Here is my Mac.
iMac (Retina 5K, 27-inch, Late 2015)
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
AMD Radeon R9 M395X 4096 MB
 Post subject: Re: Data Recovery Issue
PostPosted: April 18th, 2017, 4:54
Does the drive spin up?
Does the dock report the same 104.9MB capacity on its own, without the drive installed?
PostPosted: April 18th, 2017, 9:54
Did you try a Puppy Linux usb or dvd boot? What did its file manager report?
I was going to recommend cloning - however, at this point, it might be impossible to do.
"Take care of thy backups and thy restores shall take care of thee." Ben Franklin revisited
PostPosted: April 18th, 2017, 12:27
Based on the 2nd. image ... it has problems
have a look @ the hdd size its 100mb
Am sure you have many options/Pro`s in LA
good luck
PostPosted: April 18th, 2017, 12:56
Thanks guys, so i guess i have to take it in to a professional service to get repaired? Anyone have any recommendations in Los Angeles?
PostPosted: April 18th, 2017, 12:57
it does not spin when connected... and when the drive is not connected no info is shown as far as disk size
PostPosted: April 18th, 2017, 13:19
Hi, put the drive into the dock and power it up.
When it's recognized open terminal and write diskutil list....take a screeenshot and post it here.
http://www.rescue-it.se
PostPosted: April 18th, 2017, 13:31
Obviously, not everyone actually reads what you say before they throw their 2 cents in there. If the drive's not spinning, then you're clearly going to need the assistance of a professional lab. Tying to diagnose a hardware issue like that using only software is an exercise in futility.
PostPosted: April 18th, 2017, 13:57
Sorry did miss that when I wrote...yep either pcb is gone or heads...you'll need pro-assistant.
PostPosted: April 18th, 2017, 15:28
If it is a PCB problem, as it appears to be, then you could try a PCB plus firmware transfer for around US$50.
If you could upload a detailed photo of the component side of the PCB, I could help you to narrow down the problem. It may be as simple as a shorted TVS diode, in which case a DIY fix may cost you nothing.
PostPosted: April 18th, 2017, 17:15
FD2002 Mac OSX El Capitan Drive Dock Error - ASMT109x:
http://www.inateck.com/forums/forum.php?mod=viewthread&tid=499
For 6 months I've been using the Inateck FD2002 on an early 2008 Mac Pro (MacPro3,1) running El Capitan (10.11.2) and I've noticed that if I turn on the dock with no external drive inserted into the dock I will get an error "The disk you inserted was not readable by this computer", with the choices: Initialize, Ignore, Eject:
If I select Eject and I insert a drive, the external drive will spin up but it will not mount so I'm unable to access it.
If I select Ignore and I insert a drive then the external drive will spin up and I can access it normally.
If I select Initialize, then the OSX Disk Utility will open automatically and it sees the attached FD2002 as having some uninitialized storage space "ASMT109x - Config Media" 104.9MB Uninitialized.
PostPosted: April 18th, 2017, 18:18
RolandJS wrote:
Did you try a Puppy Linux usb or dvd boot? What did its file manager report? I was going to recommend cloning - however, at this point, it might be impossible to do.
I need glasses! If the first post mentioned the HD was not spinning -- I totally missed it. I was focused primarily on the data recovery question as given in the title.
PostPosted: April 18th, 2017, 23:46
Here is a photo of the drive. any other suggestions?
Users browsing this forum: Google [Bot] and 52 guests
