 Post subject: Dead Samsung EVO 850 250GB
PostPosted: April 23rd, 2017, 11:40
Dear readers,
I have this disc that gives no sign of life when it is plugged into a computer.
It does not show up in BIOS.
My guess (or at least home) is that there is a fuse somewhere that could be fixed.
Is there any pro out there who can point me in the right direction?
I would appreciate your help!
Thanks!
http://forumbilder.se/G82SA/img-4896-s
http://forumbilder.se/G82SA/img-4895-s
 Post subject: Re: Dead Samsung EVO 850 250GB
PostPosted: April 23rd, 2017, 17:08
Measure the marked voltages.
PCB protection devices - Electronic Fuse:
http://www.hddoracle.com/viewtopic.php?f=100&t=1615&p=8872
PostPosted: April 23rd, 2017, 18:56
The 14-pin IC adjacent to V1 and V3 could be a TPS22966. I would check the two Vouts.
TPS22966, Texas Instruments, 5.5V, 6A, 16-mohm ON-Resistance Dual-Channel Load Switch, marking RB966:
http://www.ti.com/lit/ds/symlink/tps22966.pdf
PostPosted: April 24th, 2017, 2:44
Dear fzabkar,
Thanks for your help!
I have measured all points you marked for me:
V1 1.10Vdc
V2 3.05Vdc
V3 1.87Vdc
V4 1.81Vdc
V5 12.15Vdc
V6 1.10Vdc
V7 1.26Vdc
At the e-fuse:
Vin 5Vdc
Vout 5Vdc
14 PIN
Vout1 1,81Vdc
Vin1 1.81Vdc
Vout2 1.26Vdc
Vin2 1.26Vdc
Bias 5Vdc
http://forumbilder.se/G82V8/singleshot0000
Looks quite suspicious that the Vin and Vout are the same at the 14pin IC?
PostPosted: April 24th, 2017, 9:36
Please try to attach it to a Linux system and look at the output of "dmesg", whether you see anything there.
If you get messages like "COMRESET failed" after about 10-20 seconds, then the SSD hangs during initialisation.
PostPosted: April 24th, 2017, 13:40
I've done the measurements, here are the results:
V1 1,10Vdc
V2 3,05Vdc
V3 1,87Vdc
V4 1,81Vdc
V5 12,15Vdc
V6 1,10Vdc
V7 1,26Vdc
At the e-fuse:
Vin 5Vdc
Vout 5Vdc
14 PIN
Vout1 1,81Vdc
Vin1 1.81Vdc
Vout2 1,26Vdc
Vin2 1,26Vdc
Bias 5Vdc
Looks a bit wierd that the Vin and Vout are the same on the 14pin IC, am I right?
PostPosted: April 24th, 2017, 14:12
Hi Sourcerer,
Nice advice, its not completely dead afterall :)
attached a log
dmesg.txt [6.85 KiB]
Downloaded 1355 times
PostPosted: April 24th, 2017, 15:55
RB966 is a switch, so Vout = Vin. All the voltages look OK.
PostPosted: April 24th, 2017, 17:29
ISTM that the drive IDs correctly, but does not allow read access.
[  110.831727] scsi 8:0:0:0: Direct-Access     Samsung  SSD 850 EVO 250G B    PQ: 0 ANSI: 0
[  110.832233] sd 8:0:0:0: Attached scsi generic sg8 type 0
[  110.832787] sd 8:0:0:0: [sdi] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[  110.833899] sd 8:0:0:0: [sdi] Write Protect is off
[  110.833903] sd 8:0:0:0: [sdi] Mode Sense: 3b 00 00 00
[  110.836165] sd 8:0:0:0: [sdi] No Caching mode page found
[  110.836171] sd 8:0:0:0: [sdi] Assuming drive cache: write through
[  296.954366] sd 8:0:0:0: [sdi] tag#0 FAILED Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
[  296.954373] sd 8:0:0:0: [sdi] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
[  296.954376] blk_update_request: I/O error, dev sdi, sector 0
[  296.954380] Buffer I/O error on dev sdi, logical block 0, async page read
Does smartctl (Linux) provide any information?
PostPosted: April 25th, 2017, 6:14
Didn't have the SMART sw installed on this Linux machine and no internet for now.
I will install it and check the SMART as soon as I can.
PostPosted: April 25th, 2017, 6:32
Did you try to attach it through a USB-SATA interface? Is possible, please also try a native (PCI/...) SATA interface instead. (The USB2-SATA adapters usually hide some details due to limitations in the USB mass-storage protocol.)
Yes, it seems that the SSD starts but it has problems reading your data later on.
Has the SSD been unpowered for a longer period of time? (Months)
Does the SSD case look legitimate? The output from your logfile looks a bit strange to me, but I am not sure. I have seen a fake Samsung SSD in the wild already (which was sold by a reputable dealer). The indicators I found on that fake SSD were the following:
* A Samsung Logo was missing on a sticker on the SSD
* The serial number format was wrong
* A sticker was attached on the wrong side of the SSD, not covering the screwholes
* The firmware version it reported did not adhere to the Samsung Firmware number scheme
* Samsung Magician did not recognize it as a Samsung SSD
So I would suggest to also install Samsung Magician from the Samsung website, and have it analyze the SSD. (In addition to running hdparm -I and smartctl --all as fzabkar already suggested)
I think for Samsung Magician it might be also better to use a native SATA interface, without USB.
PostPosted: April 25th, 2017, 7:01
Yes, I used USB-SATA adapter. When I use native SATA I get this:
[  218.239847] ata5: exception Emask 0x10 SAct 0x0 SErr 0x4090000 action 0xe frozen
[  218.239853] ata5: irq_stat 0x00400040, connection status changed
[  218.239856] ata5: SError: { PHYRdyChg 10B8B DevExch }
[  218.239863] ata5: hard resetting link
[  218.962561] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  223.962551] ata5.00: qc timeout (cmd 0xef)
[  223.962568] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) failed (Emask=0x4 Stat=0x50 Err=0x01)
[  223.962575] ata5: hard resetting link
[  229.322554] ata5: link is slow to respond, please be patient (ready=0)
[  233.970554] ata5: COMRESET failed (errno=-16)
[  233.970565] ata5: hard resetting link
[  239.330549] ata5: link is slow to respond, please be patient (ready=0)
[  243.978545] ata5: COMRESET failed (errno=-16)
[  243.978555] ata5: hard resetting link
[  249.338545] ata5: link is slow to respond, please be patient (ready=0)
[  279.030535] ata5: COMRESET failed (errno=-16)
[  279.030547] ata5: limiting SATA link speed to 1.5 Gbps
[  279.030550] ata5: hard resetting link
[  284.054551] ata5: COMRESET failed (errno=-16)
[  284.054573] ata5: reset failed, giving up
[  284.054588] ata5: EH complete
There is the "COMRESET failed" you mentioned earlier.
So it hangs. Is it fixable?
It might have been unpowered for a longer time, I don't know but I could ask.
I really doubt this is a fake Samsung SSD. I have one of my own and it looks exactly the same.
I cant get any SMART attributes from the device. The terminal just freezes when I run the commands.
PostPosted: April 25th, 2017, 14:41
The main goal not clarified. Do you need data or just repair device? In first case it is possible to do, need to run it in tech-mode, connect to terminal (Rx-Tx) and download specific microcode. So far it is possible only with expensive tools like (pc3k ssd edition).
Angel Data Recovery
PostPosted: April 25th, 2017, 15:16
Hi Kiev,
Yes, the main goal is to recovery the data!
Don't really care about the disc itself.
Since I don't have access to pc3k, I guess I'm screwed?
PostPosted: April 25th, 2017, 17:15
Hmm, ok, so it seems more like the USB bridge was too optimistic about the COMRESET/COMINIT handshake. So the firmware does not start correctly.
It seems very much like the problem I have with my EVO 840 250GB. You can read about my experiences with the EVO 840 here: http://www2.futureware.at/~philipp/ssd/ ... Manual.pdf
I guess that most of it applies to the EVO850 as well, but I haven't had the time to investigate the EVO850 deeper yet.
Since you do not have access to a PC3K and you want your data recovered, I would suggest that you send your SSD to a data recovery company that has access to a PC3K.
If you are interested in a DIY method, what I can currently offer is a method to dump the raw (encrypted) FLASH sectors. But I do not have a method to decrypt and reconstruct them yet.
PostPosted: April 26th, 2017, 5:23
Thanks allot for your time, trying to help me out!
I will consider sending it to DR after all.
Take care!
PostPosted: May 2nd, 2017, 3:40
Take care!
We can have a look on it, I think at this stage it won't be that expensive.
Bosse
http://www.rescue-it.se
Users browsing this forum: Majestic-12 [Bot] and 24 guests
