 Post subject: ST500LT012 - LED:000000BC FAddr:00007A43 stuck on bsy
PostPosted: April 29th, 2017, 10:41
I have ST500LT012 the drive spin for few second then stop and the head is moving (not stuck). then it gets DRD DSC.
but when I try to read ID i stuck on BSY DRD DSC until I power OFF/ON the hdd.
and when I start utilities this is what I get:
and after repowering I get in the terminal:
Rst 0x10M
SPINUP FAILED
ExecuteSpinRequest
op=0100 resp=0007
op=0100 resp=0007
CfwDiscCode Not Loaded: 0002B4E0
 Post subject: Re: ST500LT012 - LED:000000BC FAddr:00007A43 stuck on bsy
PostPosted: April 29th, 2017, 12:51
Overlay wasn't loaded. Probably, due to some damages in SA.
PostPosted: April 30th, 2017, 9:46
I suspect bad media but I'm curious why the "SPINUP FAILED" message. The drive spins up fine with HDA isolated, so it's not seized spindle.
PostPosted: April 30th, 2017, 10:26
Because this massage relates to servo recalibration, not to SPIN UP literally. And yes, you have to think about heads replacement, current heads are not good with big probability.
Users browsing this forum: No registered users and 96 guests
