 Post subject: ST1000LM024 SPIN ISSUE
PostPosted: May 9th, 2017, 3:30
Defective Drive
ST1000LM024
HDD P/N HN-M101MBB/AV1
REVA
F/W 2AR20002
S/NS2ZPJ9FD450744
DONOR
ST1000LM024
HDD P/N HN-M101MBB/D2
REVA
F/W 2BA30001
The first Drive spins perfect If the heads are on parking
when the heads moves on platter it stops
I replaced heads from second drive the HDD doesn't spin even heads are on parking
 Post subject: Re: ST1000LM024 SPIN ISSUE
PostPosted: May 9th, 2017, 3:43
Where are the terminal logs from pacient and donor in original condition, pacient after head s replacement - ...?
PostPosted: May 9th, 2017, 3:53
In this case donor means drive working in laptop
From this drive i replaced heads
PostPosted: May 9th, 2017, 4:18
my guess..incompatible heads
PostPosted: May 9th, 2017, 5:34
With high probability you have uncompatible preamps. To be sure, better to see a terminal log.
PostPosted: May 9th, 2017, 5:57
Hello
Martin and jerry1
You both may be right
I fixed old heads to same defective drive
Now heads moves on platter it stops
PostPosted: May 9th, 2017, 10:33
incompatible heads +1
what's the terminal log of your patient and donor
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: May 12th, 2017, 5:24
+1, incompatible heads
Data Recovery Pakistan
PostPosted: May 14th, 2017, 11:56
Well,
if you need my help i can do this recovery for you .this is definitely a incompatible preamp headstack for your patient buddy
PostPosted: May 14th, 2017, 13:45
Amarbir[CDR-Labs] wrote:
Well,
Thank you Guru ji
I got same HDD got data
Here In where I am living South India. it's hard to get regarding HDD data recovery like hard disks. I will write in ur PM
PostPosted: May 16th, 2017, 13:02
Well,
Thank you Guru ji
We are now handling many physical cases from south india on routine basis .This includes some big companies in grade A cities .Though i will prefer that the hods are not opened before they come to me so that success rate is high .If you follow my Facebook page you will know that sometimes we do fantabolous work
PostPosted: May 17th, 2017, 2:28
Can you post the SN of the DONOR DRIVE?
Users browsing this forum: No registered users and 112 guests
