 Post subject: Hitachi Drive Fail
PostPosted: May 30th, 2017, 9:17
I bought a Mac Mini server with two Hitachi 500gb sata drives. These drive were the original drives. The first drive, Mac HD, is the system drive and the second drive, Untitled, is a spare drive. After I turned on the server, I noticed the Untitled drive automatically unmounted and I decided to take the drive out and test it. I ran First Aid and FA could not repair the drive. Also, I ran Disk Warrior and DW could not repair the drive either.
Since FA and DW could not repair the drive, I guess this means the drive has some type of hardware failure. Is there any other tests that I could run just to be sure the drive is bad? I am sure that First Aid and Disk Warrior are correct. I am thinking the drive needs to be replaced. I don't know if I could erase the drive and perform a secure erase, maybe that would give more life to the drive. Perhaps, that will be a waste of time and the drive has some type of hardware defect.
 Post subject: Re: Hitachi Drive Fail
PostPosted: May 30th, 2017, 9:25
Just to add, there is no clicking sounds or unual noises. The drive has power. Currently, I have it attached to my Mac and I am waiting for DU to display the drives. This is what makes me think there is something hardware related with the drive. The drive is not being mounted so I believe the drive is bad.
PostPosted: May 30th, 2017, 11:11
Ideally, you could connect the drive to a pc computer and run Hitachi“s WinDFT tool. That would allow testing of the disk, and also erasing it. Also, Mhdd or Victoria could do the test and erasing too.
Users browsing this forum: pepe and 228 guests
