 Post subject: BSY Fix and Lost Partitions
PostPosted: June 10th, 2017, 6:39
seagate st31000528as
bsy fix executed by user. with no success.
Now Hdd seems but data lost. sector readable.
he says there are more than 700 gb data in it.
there are some bads at the beginning and all bad after the 699 gb.
data can't visible at all. All LBA with 0 except first. Why?
because of MFT record area has bad sector?
 Post subject: Re: BSY Fix and Lost Partitions
PostPosted: June 10th, 2017, 7:22
interesting with busy fix, all LBA's 0.
are you absolutely sure that all LBA's are zero 0000 ?
Data Recovery Pakistan
PostPosted: June 10th, 2017, 7:43
What does it really mean when you say, "BSY fix by the user?'. What exactly did they do?
PostPosted: June 10th, 2017, 9:39
he clears G-List by i4,1,22
and translator regenerate by m0,2,2,,,,,22
sectors aren't partial now. it's readable... but the data flys..
i think last heads gone...
PostPosted: June 10th, 2017, 12:52
Are there errors in the terminal ? Has the user tried the "brilliant" idea of formatting the drive to try to recover it ?
PostPosted: June 10th, 2017, 17:19
No.. no terminal error
and it can not be formatted because drive was not visible on device manager..
he said that he don't format ..
PostPosted: June 17th, 2017, 9:05
I THINK ITS PSA ( Partial Access Problem) ++++++++
1. YOU TRY REVERSE CLONING
2. CHECK NRG LIST IN TERMINAL
PostPosted: June 18th, 2017, 3:13
Spildit, +1 AGREE ....
Users browsing this forum: No registered users and 55 guests
