 Post subject: WD BLACK DUAL DRIVE 120 SSD 1TB HDD compatibily
PostPosted: June 6th, 2017, 4:44
Hi guys,
I have 1 drive WD1001X06X Dual Drive SSD/HDD and the heads are weak.
Does any one know what SATA model is compatible for Head Swap without the same model, because its very expensive?...
SSD is okay the HDD needs to replace the heads.
I apreciate some help in this case, thanks in advance :)
Data Recovery Technician - If Data is important don't DIY without knowing the real problem.
 Post subject: Re: WD BLACK DUAL DRIVE 120 SSD 1TB HDD compatibily
PostPosted: June 6th, 2017, 8:48
What's the aerial density of the drive? Sometimes by just matching that you can cross match heads between families.
PostPosted: June 6th, 2017, 10:58
infofaster wrote:
Hi guys,
Well,
I am glad to see you back after a long time :D
PostPosted: June 6th, 2017, 22:08
According to this review, the drive is a 1TB WD Slim:
https://www.eteknix.com/western-digital-black%C2%B2-dual-drive-120gb-ssd-1tb-hdd-review/2/
The DCM of the WD1001X06X-00SJVT0 hybrid drive is HHVJBHO. FWIW, the same DCM appears in WD10SPCX-08HWST0, WD10SPCX-11HWST0, and WD10SPCX-75HWST0.
PostPosted: June 7th, 2017, 5:20
"Well,
I am glad to see you back after a long time :D"
Its nice to be back Amarbir[CDR-Labs], its been a while i have been busy.
But when i got some new topics i ask here ;)
fzabkar i saw the models you tell me and yes its slim drive tho, but is the family and the heads patern compatible?
You have allready test it?
Thanks guys for the replys, regards :)
PostPosted: June 7th, 2017, 13:37
infofaster wrote:
"Well,
Frank does not do physical hdd recoveries .I am not sure he will be able to tell you ,If you send me the roms of both the drives i can try my best to tell you if they will work ,But you have to first buy the sata drive :D
PostPosted: June 7th, 2017, 15:12
I have written a tool which extracts certain information from the ROM.
WD1001X06X-00SJVT0
Analysing active 0x0A module ...
Head map checksum (Expected / Actual) = 0x0000 / 0x0000 - OK
Number of heads (physical / in use) = 4/4
Head map = 0x0F
      S B L P M H C R V K U
      | T | T Z T Q D S J E
DCM = | T | T Z T Q D S E
      : : : : : : : : : unknown
      : : : : : : : : top VCM
      : : : : : : : ACA
      : : : : : : preamp
      : : : : : HSA
      : : : : media
      : : : bottom VCM
      : : latch
      : base
      spindle motor
Analysing active 0x47 module ...
Preamp values
0  951B 0837
1  951B 0A33
2  3512 0839
3  A41F 0439
PostPosted: June 8th, 2017, 6:26
I have bought the drive, now im waiting that arrive. Then i will save the FW, ROM and check the pattern if is equal from the original.
Give news soon :)
PostPosted: June 20th, 2017, 7:48
Does any one swap the heads from this drive? inside doesn't have space to remove from the parking area to outside.. the chassi is very close.. This one will be complicated even when i get the papers in the middle of the arms.
PostPosted: June 20th, 2017, 13:11
I Am Not Sure If This Tool Fits Your Current Job Profile But Mr Nikola Has The Same
WD Slim Toolkit -> http://hddsurgery.com/data-recovery-too ... 5-slim-set
WD Slim Platter Tool -> http://hddsurgery.com/data-recovery-too ... unlock-key
Users browsing this forum: No registered users and 63 guests
