 Post subject: I need fujitsu MHT2030AT Rom image (pictures)
PostPosted: June 29th, 2017, 11:12
 Post subject: Re: I need fujitsu MHT2030AT Rom image (pictures)
PostPosted: June 29th, 2017, 21:22
It's a MHT .....
Why do you need a rom?
PostPosted: June 30th, 2017, 0:34
I will match the PCB and will start the drive directly. Even the capacity does not matter as far as PCB is a match.
PostPosted: June 30th, 2017, 0:59
colanco wrote:
It's a MHT .....
The room is burned
PostPosted: June 30th, 2017, 1:06
Sorry Rob but I do not understand your answer. My bios is burned,
PostPosted: June 30th, 2017, 5:04
Are you sure about this in the MHT series ???
PostPosted: June 30th, 2017, 5:08
navafigo wrote:
colanco wrote:
It's a MHT .....
The room is burned
I have not worked much with these but I'm afraid the rom has adaptive in MHT series
PostPosted: July 1st, 2017, 0:58
@ navafigo
You are right. i misread it.
Its a MHT
@ navafigo
Can you post a picture of broken ROM ?
May be pins can still be exposed and a wire be soldered to pins and copied.
Users browsing this forum: Google [Bot] and 228 guests
