Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Small scratch on edge of platter - is it over?
PostPosted: May 2nd, 2017, 14:52
drHDD wrote:
They took out platters to see all surfaces and then putted them back. Do you still sure in good result?
Well,
Platters can be taken out all together and even one by one without loosing platter alignment and also inspection can be done .A custom tool can separate platters ,help you in visual inspection and reassemble them back so they work ,but the story changes when it has passed via a lab with lousy techs i recently got a seagate case were top platter was scratched when top head was not ever present in headstack lol
PostPosted: May 3rd, 2017, 14:50
Banned User
Did you manage to image it and recover successfully bro? What is the process that happens after the imaging process in detail? thanks!
PostPosted: May 5th, 2017, 10:17
Banned User
after a successful imaging, is there a chance that the data is unreadable due to system area damage? Are there any algorithms or software that can decipher it?
PostPosted: May 5th, 2017, 17:37
without system area access it is not possible to read a single sector from the drive, so it is the very first step to gain access to important SA objects.
PostPosted: May 6th, 2017, 2:22
Encryption on the desktop internal HDD is enough rare situation (if we are not talking about malware). If your drive has been imaged successfully, so what is the problem to get access the data?
PostPosted: May 6th, 2017, 13:33
Banned User
Do you mean that even after imaging 100%, without SA, you are still unable to access data? How do you gain access then? Thanks bro
PostPosted: May 9th, 2017, 4:26
perhaps they used RAW rec, which is crap on Ext fs unless written smart. Just an idea how it can be truncated...
btw, it is not appropriate to say the drive imaged 100% when it's not. If they cloned 95% but the FS metadata is in the remaining 5% it can bring up some problems.
PostPosted: May 9th, 2017, 16:52
An hot swap would be completly out of the question
hotswap is not out of question, but probably not the case here.
PostPosted: May 9th, 2017, 18:52
i just meant it can be done. But i don't think the actual recovery has gone this far.
PostPosted: May 10th, 2017, 11:40
Well,
For These DM series i have given up .Mostly they end with bad platter surface and scored media .As fas as hot swap is concerned ,We can take a donor after we initialise it using translator etc from other patient .Then make it standby swap donor heads to patient and voila .But who goes this farrrrrrrr offffffff
PostPosted: May 17th, 2017, 1:51
Banned User
what are some of the software available out there to translate the data? Will it be successful?
PostPosted: July 3rd, 2017, 6:58
really sorry to bring my thread up again as I have been banned previously for asking regarding this issue. I am not a tech person and just want my data back. I am confused at what is happening and am trying to seek help here from you seniors.
The DR firm managed to image my drive but the result is in raw data form and is not readable as the files are all messed up. They said they are unable to read the data properly. Is there any recommendations anyone can make? Thank you once again for any advice.
PostPosted: July 4th, 2017, 4:12
Eh, it seems i was on the spot then with the RAW recovery idea....
I think there is no more recommendations we can give unless sending the bad drive and the image for further investigation.
PostPosted: July 4th, 2017, 4:47
Dear Pepe, do you mean your reply on 9th May? This one
PostPosted: July 5th, 2017, 7:33
yes, i meant that but as you told me it wasn't Ext but NTFS, it puts things in a different perspective.
PostPosted: July 5th, 2017, 20:47
I could look your drive, if you can send it to me.
PostPosted: July 7th, 2017, 12:02
yes I have pm-ed him, thanks for the suggestions! Would it be possible to recover from a scratched platter? is getting the drive to image the hardest part?
PostPosted: July 8th, 2017, 9:32
It is not possible to say yes or no responsibly without evaluating the damage. What's not possible for one company might be possible for another... I also recovered many drives others refused or failed. Economical questions also arise sometimes.
PostPosted: July 10th, 2017, 11:33
I sense that the OP is not interested in your offer, @drHDD. He just keeps posting more questions on Toms Hardware - http://www.tomshardware.com/answers/id- ... l#19921551
Recovery Force Data Recovery
PostPosted: July 10th, 2017, 18:10
It is starting again to look as if the question is not real.
Users browsing this forum: No registered users and 73 guests
