 Post subject: HGST recovery success rate
PostPosted: April 13th, 2017, 7:19
I would like to know what is overall success rate for HGST Z7K500-500 HTS725050A7E630 head transplant.
I have very poor success rate & for unknown reasons head transplant fails.
I know ultimate success depends upon individual skills , tools and platter condition ,but in this case disk was making higher pitch clicking ,even after head transplant from healthy donor , disk tends to make same noise and stays busy.
There was no visible scratches on upper platter .
Is this due to high RPM ? What is all of your experience for this model. I want to know where I am wrong and how can I improve.
 Post subject: Re: HGST recovery success rate
PostPosted: April 13th, 2017, 8:13
We usually get most of them, but having PC3K makes a huge difference in that.
PostPosted: April 13th, 2017, 10:01
@bunty
Test your technique on two working drives, not a damaged one. Then you will know if the technique is right or not.
Often, media damage on Hitachi is on lower surfaces, not top.
PostPosted: April 13th, 2017, 12:33
Got one in right now...heads are still alive. There is a lot of media damage with both heads in first 20% of the drive, but as we get to higher LBAs, both heads read fine. It is Mac encrypted, making it a little more essential to get the best clone possible.
PostPosted: April 13th, 2017, 17:11
HGST has very weak platters , for me i have bad rate in Hitschi 2.5 ...
you have to check the original heads .. is its bint means it eill eat all the heads u will replsce later..
PostPosted: April 13th, 2017, 18:55
Z7K320-320 also arrived today. Head 0 read 100% and head 1 is dead. Will likely get a full clone after a head change next week.
PostPosted: April 14th, 2017, 0:15
Hi guys
Thanks for sharing your experiences.
originally disk was making loud noise , after head swap there is no change in symptoms.
There was no visible damage to top platters. Unfortunately if heads put back in donor , donor has lost detection and it also stays busy. (no clicking noise comes)
patient has damaged donor heads. I will have to purchase new donor now.
My worry is even second set get damaged , there will be big loss. Customer is not going to pay cost of donors :(
PostPosted: April 15th, 2017, 15:11
Maybe the approach you using of replacing the HSA is wrong
In order to check it, you'll have to practice to replace a HSA from one "good working" drive to another "good working" drive
PostPosted: April 17th, 2017, 1:25
If drive has media damage, heads should die. If heads are still working - it's not media damage.
PostPosted: July 12th, 2017, 0:09
I think it cause by high RPM.
PostPosted: July 12th, 2017, 5:26
Good drives for data recovery. Only lost original PCB could make a headache.
Users browsing this forum: No registered users and 53 guests
