 Post subject: SATA instead of USB PCB - how to ID it ?
PostPosted: July 20th, 2017, 12:42
Got a WD elements with a tiny USB (Thunderbolt size) come in and I need to find the right SATA PCB to install on it so I can get it hooked up to the DDI.
How do I go about finding the right donor drive / PCB so I can then transplant the chip across and spin it up ?
Thanks in advance.
 Post subject: Re: SATA instead of USB PCB - how to ID it ?
PostPosted: July 20th, 2017, 16:29
As a general rule, find a SATA PCB with the same MCU and motor controller.
PostPosted: July 20th, 2017, 17:10
I wish I had photographed it before leaving work :cry:
is the MCU and motor controller etched into the PCB as numeric codes ?
PostPosted: July 20th, 2017, 17:15
See http://forum.acelaboratory.com/viewtopic.php?t=8578
Identifying HDD IC markings - ST313021A case study:
http://www.hddoracle.com/viewtopic.php?f=59&t=207
PostPosted: July 20th, 2017, 17:21
I have been schooled :D
Many Thanks 8) 8)
PostPosted: July 20th, 2017, 17:50
There is list I've been keeping here on my forum: https://www.data-medics.com/forum/wd-pa ... e-t13.html
You just have to match the PCB number and see the corresponding SATA board. I started the list based on what Ace Lab posted on their blog, but there's been a lot added since Ace first posted their list of cross compatible boards.
PostPosted: July 20th, 2017, 18:30
thanks Jared :wink: i'll post on it in the morning when I can ID the drive from work
PostPosted: July 21st, 2017, 8:23
Looks like I need 701692 according the lists on your forum.
Is there a quick way to know what drives they would be on or do I have to look at all the WD donor drives I have in stock ?
PostPosted: July 21st, 2017, 8:27
WD My Passport
PostPosted: July 21st, 2017, 9:31
http://ts.acelaboratory.com/index.php?/ ... usb-drives
PostPosted: July 21st, 2017, 9:32
So you'll need a 1692 PCB and switch the U12 chip, then figure out a way to decrypt the clone (assuming it is encrypted, most are)
PostPosted: July 21st, 2017, 10:48
Thankfully this one isn't encrypted, I just need to source a PCB with the MCU 701692.
Drives arn't listed by that code so ....
how can I match that code to a series / family of drives so I can look for one ?
PostPosted: July 21st, 2017, 10:58
http://blog.acelaboratory.com/pc-3000-h ... drive.html
Just in case if you wanna try out the above method. Manually solder out the wire to the SATA Port.
PostPosted: July 21st, 2017, 23:42
For your case with pins E71, E72, E73 and E74, can refer to this post to try out:
http://www.datarecoverytools.co.uk/2010 ... tor-suite/
agent007 wrote:
http://blog.acelaboratory.com/pc-3000-hdd-how-to-solder-a-sata-adapter-to-the-usb-western-digital-drive.html
P/S: For an older board
PostPosted: July 22nd, 2017, 0:40
The following article should help you to understand the difference between a PCB and an MCU:
HDD from inside: Hard Drive Main parts:
PostPosted: July 22nd, 2017, 3:16
You need a Zephyr SATA drive and swap the EEPROM. Then decrypt the image.
PostPosted: July 22nd, 2017, 4:49
ok its established I need a 701692 PCB but what remains unclear to me is how to find one ?
Is it only found on WD models (I'm assuming its vendor specific) ?
Without buying hundreds of 2.5" WD drives and manually looking at the PCB numbers how else can I identify drives that might have that PCB number ?
PostPosted: July 22nd, 2017, 6:35
The 2060-701692 PCB is used by both WD and Western Digital.
The 2060-771692 PCB (also by WD) is most likely suitable as well.
PostPosted: July 22nd, 2017, 9:51
This site is really good by the way - thanks for linking that :)
PostPosted: July 22nd, 2017, 9:58
2060-701692 - can't find any on eBay
2060-771692 - lots of these available but it only has 1 bios chip area does this matter ?
Can I get away with buying this PCB and transplanting U12 onto it ?
Users browsing this forum: No registered users and 229 guests
