 Post subject: USB to SATA pinout FOR M9T BP
PostPosted: July 24th, 2017, 8:40
i am looking for a pinout to transfor this pcb into a sata one.
FOR M9T BP
 Post subject: Re: USB to SATA pinout FOR M9T BP
PostPosted: July 24th, 2017, 15:05
As a general rule, locate a photo of a SATA PCB with the same MCU, and then follow its SATA Tx/Rx differential pairs from the MCU to the SATA connector.
PostPosted: July 25th, 2017, 0:42
See attached pic.
DF :)
DF :)
www.datatracksystem.net
PostPosted: July 25th, 2017, 1:16
It's not the same MCU (88i1022-NDB2 versus 88i1025-NDB2), but it looks very similar:
https://sep.yimg.com/ay/yhst-14437584971410/91504261-6.gif
PostPosted: July 25th, 2017, 1:53
You quoted Seagate Rom and PCB above are of Samsung USB. both are different.
DF:)
DF :)
PostPosted: July 25th, 2017, 2:16
DF:)
As I said, it's not the same MCU, but its pinout is similar. This means that the OP need only follow the 88i1022 MCU pins to the SATA connector. The 88i1025 CPU will most likely have exactly the same SATA Tx/Rx correspondence.
I was not suggesting that the two PCBs were interchangeable.
PostPosted: July 25th, 2017, 10:23
There are SATA M9T drives in the world
PostPosted: July 25th, 2017, 15:31
Yes, but which one has the OP's MCU and motor controller (assuming I've read the part number correctly)?
PostPosted: July 25th, 2017, 16:07
I'm pretty sure it's PCB number: 100731207
I've been keeping a list of those on my forum too: https://www.data-medics.com/forum/samsu ... t1438.html
PostPosted: July 25th, 2017, 16:18
I had already seen your database. Thanks. However, your PCB has an 88i1022-NDB2 MCU whereas the OP's appears to be 88i1025-NDB2.
PostPosted: July 25th, 2017, 16:21
100767980 and probably some others (aka SATA M9T BP) has 88i1025
Users browsing this forum: Google [Bot], nevermind and 57 guests
