 Post subject: Seagate SSHD ST2000DX001
PostPosted: July 21st, 2017, 7:28
I have a hybrid 2TB hdd/ssd (Seagate ST2000DX001) which, a couple of weeks ago, began to intermittently make Windows 10 unresponsive. Checking the event viewer revealed that "the disk has a bad sector." I immediately got a new HDD, installed Win10 from scratch, re-connected the old drive as a secondary, and began copying selected directories over to the new drive. This was going fine for a while, then the old drive stopped putting out.
I powered down the system, and the drive has not been recognized by the bios since. It is spinning up, but the mobo refuses to see it. I have tried different sata ports, even putting it in an external enclosure and connecting it via an esata port - still no go. When powered up, I hear the disk physically spin up and make one of two sound sequences - three bursts in one, four in the other with one of them being higher pitched. I uploaded a couple of MP3s of what it sounds like to Dropbox - https://www.dropbox.com/sh/9miqy4ooywzt ... egKaa?dl=0
Can anyone tell from the sound of it what the issue could be? If I can't get the mobo to recognize the drive, are there any tools I can use to get into the thing and give it a kick in the pants? There is still data on the drive that I'd really like to get off of it - trying to avoid spending the $550 to get the data back.
 Post subject: Re: Seagate SSHD ST2000DX001
PostPosted: July 24th, 2017, 9:01
Can I assume from the lack of replies that I'm pretty much out of luck on this one?
PostPosted: July 24th, 2017, 11:25
it's complicated - HDD + SSHD
you need professional tool -
which tools do you use ?
PostPosted: July 24th, 2017, 12:01
Sounds like physical issues to me, not DIY :-(
PostPosted: July 24th, 2017, 12:09
yes or the init nand issue but still under phisical one..
PostPosted: July 24th, 2017, 15:46
I currently have no tools - downloaded "Seagate Tools" which was, of course, worthless. Barely useful only if the drive is recognized by the bios. I was wondering if there was a piece of software out there that could maybe do some sort of low-level operations on the drive even if it's not recognized by the mobo. (Note: complete noob in this arena, decades of other tech experience)
PostPosted: July 25th, 2017, 17:58
i recommend contacting some pro in your area.
PostPosted: May 18th, 2021, 22:17
i need complete fw for this
rom
ldr
3d ldr
please
PostPosted: May 25th, 2021, 7:32
For what device?
PostPosted: June 9th, 2021, 8:07
sorry for late
i need for mrt supported
please
Users browsing this forum: Google [Bot] and 270 guests
