 Post subject: WD3200LPVX (Hubble LT) ram reading error and no access Sa
PostPosted: August 1st, 2017, 0:20
I upload ldr but I cannot solve my problem
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
Zone allocation table................... : HDDs RAM reading error Device Error Detected: "SCT INVALID FUNCTION CODE"
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 104 056
SA regions address...................... : by default
Module 02 access........................ : Granted
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 06.16J
ROM F/W version......................... : 00060016
Overlay F/W version..................... : 06.17J
Servo F/W version....................... : NB.11
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirActSpeed
SA SPT Detect........................... : FAIL
SA dir reading (ABA/CHS)................ : Module reading error: ABA 471 928(1) reading error Physical read error C/H/S: -48/1/57 Device Error Detected: "SERVO ERROR CODE BASE SvirActSpeed"
SA Access............................... : NONE
Configuration reading................... : Module 02 not found
 Post subject: Re: WD3200LPVX (Hubble LT) ram reading error and no access S
PostPosted: August 1st, 2017, 1:38
hi,
drive is calibrating normally or clicking ? try RAM Head map Edit .
PostPosted: August 1st, 2017, 5:13
did you try with Block SA Access ?
Data Recovery Pakistan
PostPosted: August 1st, 2017, 6:16
No I didnt try and I dont know how can I do that
PostPosted: August 3rd, 2017, 9:46
abi... add me on skype "WasimZafar"
Teşekkür ederim
PostPosted: August 8th, 2017, 18:33
can u attach pic of label and rom image?
