 Post subject: open case HDD. Data recover possible?
PostPosted: August 7th, 2017, 10:00
Hi.
One friend of mine just phoned me. He had a damaged external usb HDD. The drive did not work, some click sound. I guess it may be a electrical problem.
The problem is that he opened the case until he found the plates and heads.
I have said him to close it immediately and not to switch it on.
But now the question is: is the data recoverable? if so, I guess it is not a question of DIY because you will need a clean chamber.... so he will need to send it to a lab and tell them what has happened, right?
regards
 Post subject: Re: open case HDD. Data recover possible?
PostPosted: August 7th, 2017, 10:24
your quite correct - drive should not have been opened. Hopefully he/she did not poke at anything but it will need to go to a pro service and hopefully no damage has been done to the drive by opening.... I blame too many silly self help videos on youtube
it will be extremely lucky to rescue any data considering the drive has been opened in a dirty environment...
PostPosted: August 7th, 2017, 13:42
Most likely the data can still be recovered (assuming it wasn't powered on with mangled read/write heads leading to scratched platters).
We've recovered quite a few drives that were previously opened, even ones with fingerprints on the top platter. We just charge a non-refundable up-front cleaning charge to do a thorough cleaning inside of a clean chamber to get it back to a safe condition. Then we have to address the original problem, which in the case of a clicking external hard drive is probably a 99.9% chance of being failed read/write heads.
Users browsing this forum: Google [Bot], nicola and 94 guests
