 Post subject: Questions on Seagate 7200.11 refurbished recovery and donor
PostPosted: August 7th, 2017, 18:15
Hi all! Respectfully I want to ask if anyone can point me on the right direction: I have one Seagate Barracuda 7200.11 ST31000340AS recertified. The PCB is dead and the disk doesn´t spin (TVS are both OK). I get a donor, same model, same firmware and nearly same date.
I want to know if I only need to swap firmware chip (Winbond) or if I need to do extra job. Also I have a doubt about which chip has the firmware. I also have PC3k available. I include photos here.
Thank you in advance.
 Post subject: Re: Questions on Seagate 7200.11 refurbished recovery and do
PostPosted: August 8th, 2017, 2:32
That's the right chip, and yes you 100% MUST switch this chip if the original PCB cannot be repaired by you.
PostPosted: August 8th, 2017, 5:03
be careful with the swap, if you damage that chip the recovery will be pretty costy...
PostPosted: August 9th, 2017, 2:32
Very true, have seen a fair few "bodged" chip swaps which have proven to be very costly indeed :-(
PostPosted: August 14th, 2017, 19:24
Thank you very much for comments. Chip swap was successfully. I can see disk onto PC3k (wrong size). After load it on utility everything were OK and I can copy data. Best regards!
Users browsing this forum: No registered users and 84 guests
