 Post subject: Macbook Air Toshiba SSD, shorted controller T6UG1XBG
PostPosted: August 12th, 2017, 5:03
Can I just replace the controller with another one?
 Post subject: Re: Macbook Air Toshiba SSD, shorted controller T6UG1XBG
PostPosted: August 12th, 2017, 9:57
not unless you also have the Toshiba tools and software to setup the controller on the board to the NAND chips.
It is Sandforce based, so chip off is also probably out of the question.
PostPosted: August 12th, 2017, 17:14
Are you kidding, not even chip-off :(
PostPosted: August 12th, 2017, 17:33
If necessary, I can help you to confirm the voltage measurements for the DC-DC converters.
PostPosted: August 13th, 2017, 16:04
I pulled off the controller as it was burning like hell, hoping I could swap another one from another 256gb Macbook Air SSD...
PostPosted: August 13th, 2017, 16:48
Have a pic?
PostPosted: August 13th, 2017, 21:35
IMHO, worth trying as I see no other solution. Though chances extremely low.
PostPosted: August 14th, 2017, 0:37
Well,
In My experience while i used to repair desktop and laptop motherboards to chip level sometimes due to a DC - DC supply section component short the IC can burn like hell ,You panicked and yanked it of the board without confirming that ,This is not a good idea imho .
PostPosted: August 14th, 2017, 12:26
Amarbir[CDR-Labs] wrote:
Well,
There was a short in the line and it was the controller itself, sorry about not mentioning that. I checked yes.
PostPosted: September 2nd, 2020, 19:06
Hi speakerbox,
I was searching for help to fix a MacBook Air SSD, Samsung controller chip and your 2017 above topic came up. How was your experience , was it successful at the end?
It seems replacing the controller chip with another one from same type and series SSD board does not solve the problem and the controller chip needs to be setup as the data on the memory chips are encrypted.
Any help would be appreciated.
Mehdi
PostPosted: September 20th, 2020, 15:31
Hi speakerbox,
Mehdi
PostPosted: September 21st, 2020, 12:08
mvajdi wrote:
Hi speakerbox,
Mehdi
If you have a burned-out controller on a Samsung SSD, replacing the chip will help you get your data back.
Users browsing this forum: Ahmed Saeed and 138 guests
