 Post subject: Seagate F3 prompt slow to appear
PostPosted: August 12th, 2017, 2:37
how long does usually, or should the F3 CLI take to appear after pressing ctrl-z ??
the drive under test here is taking at least 2 minutes for the "F3 T>" prompt to appear, is that normal?
the terminal works fine once it appears
 Post subject: Re: Seagate F3 prompt slow to appear
PostPosted: August 12th, 2017, 3:23
that's a bit long but it means the drive is busy with other tasks. Might be a sign of head/surface problems.
PostPosted: August 12th, 2017, 22:21
thanks pepe, the G-list has no entries but SATA interface not recognised by PC. Can you advise on any troubleshooting method for the SATA interface using the F3 CLI?
I have been able to read LBA sectors via serial and the DOS partition table is there.
PostPosted: August 13th, 2017, 5:44
The output from "/TV4" contains "DiagError 00000027" - is anyone familiar with that error??
Does it relate to an error reading the Reassigned Sectors List table?? If it is, is there a method for regenerating that?
Unable to find an explanation for that error when searching, grateful for any feedback on a troubleshooting method for this error.
PostPosted: August 14th, 2017, 4:57
what does V1 show?
Users browsing this forum: No registered users and 214 guests
