 Post subject: external HD keeps flashing
PostPosted: August 24th, 2017, 4:18
My Toshipa 500gb after use keeps flashing for hrs while a warning says do not remove while it is working.
What is going on?
 Post subject: Re: external HD keeps flashing
PostPosted: August 24th, 2017, 11:05
I'm no expert but I ran into the same problem.
It was the OS (windows) indexing the drive. I removed the drive from the indexing options in the control panel.
PostPosted: August 26th, 2017, 13:19
Thank you, still trying to achieve that, so far it did bot work
