 Post subject: WD40NMZW-11GX6S1 - Need help with reading rom via terminal
PostPosted: August 29th, 2017, 10:20
Hello everyone,
Before we start, I wanted to let you all know I have already read the other threads on this particular drive. I am aware of the PCB compatibility issues between Pebbleb and Spyglass.
For these particular drives, does anyone know where to solder in order to get boot ROM access via com port? Soldering ROMs on WD drives has caused all kinds of issues in the past for me so I prefer to avoid doing it.
So far I have not found reliable information related to this subject. There are some photos of people soldering wires onto certain contacts near the USB controller. However, when trying it for myself it does not work...
What are your thoughts on this? Any suggestions? Has anyone found a Spyglass SATA PCB compatible with this drive?
Thank you kindly in advance.
Regards,
Omega
Remember, take your time. Be persistent. If you have doubts stop. Check, then proceed again.
 Post subject: Re: WD40NMZW-11GX6S1 - Need help with reading rom via termin
PostPosted: August 29th, 2017, 10:38
I forgot to add photos.
If I have to do the SATA pinouts. What caps do I remove? I have an idea as to which ones but want to confirm.
PostPosted: August 29th, 2017, 16:37
Deleted post
http://www.rescue-it.se
PostPosted: August 29th, 2017, 17:07
http://forum.acelaboratory.com/viewtopic.php?f=155&t=7397&start=30
PostPosted: August 30th, 2017, 7:53
Hi frank,
Its to be noted that atleast some time is needed before drive goes to kernel mode ,I do not have experience in this particular board but generally its 5 minutes to 6 for other usb boards
PostPosted: August 30th, 2017, 10:10
That helps at least with that part. Thank you. I may need further assistance but for now this gets me started at least.
Edit: That did not give me terminal access....
