 Post subject: Re: Rosewood
PostPosted: August 31st, 2017, 10:15
Try with this (if you have the last software version) http://ts.acelaboratory.com/index.php?/ ... ood-drives
PostPosted: August 31st, 2017, 10:41
Ys last version!
Нет ничего невозможного
PostPosted: August 31st, 2017, 12:16
No offense. I would tell the customer that you can use paperweights, it is the best utility you can find for this scrap.
It is not firmware problem, the surfaces are made of butter, there is not much expectation in most cases.
All laboratories are full of these "recent" units ..... for something will be
PostPosted: August 31st, 2017, 13:58
LOL!!! :lol:
PostPosted: August 31st, 2017, 17:06
MindMergepk wrote:
there is a way to write sysfiles with pc3k to these drives. :idea:
of course there is...
PostPosted: September 1st, 2017, 13:54
Amarbir[CDR-Labs] wrote:
MindMergepk wrote:
pepe wrote:
these drives are lacking the command to write sysfiles, so don't expect too much from pc3k.
Ts Support Ace no solution in case!!!!
Is that so i Need To Ask TS Support From Ace again Is This is The Case
PostPosted: September 1st, 2017, 16:09
Do these commands work?
    F"READ_SPARING_ENABLED",0,22
    F"WRITE_SPARING_ENABLED",0,22
    F"OFFLINE_SPARING_ENABLED",0,22
    F"DAR_ENABLED",0,22
    F"DISABLE_IDLE_ACTIVITY",1,22
    F"BGMS_DISABLE_DATA_REFRESH",1,22
    F"ABORT_PREFETCH",1,22
    F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
    F"READ_CACHING_DISABLED_ON_POWER_UP",1,22
    F"MediaCacheControl",00,22
Users browsing this forum: No registered users and 34 guests
