 Post subject: Seagate ST31000528AS 1TB 7200.12, no spin, not recognized
PostPosted: September 17th, 2017, 14:30
Greetings everyone.
The title says it all. The drive is silent, not spinning and not recognized in BIOS.
F3 2>Z
ExecuteSpinRequest
HighPowerMode = 0100
DiagError 00006002
F3 2>U
ExecuteSpinRequest
DiagError 00006008
Spin Error
Elapsed Time 5.397 secs
R/W Status 2 R/W Error 84150180
F3 2>Z
Spin Down Complete
Elapsed Time 0.084 msecs
F3 2>U
ExecuteSpinRequest
ExecuteSpinRequest
DiagError 00006008
Spin Error
I have removed PCB and cleaned contacts. No change.
Is there anything else I can try? Any wisdom that can be gleamed from the diagnostics I posted?
 Post subject: Re: Seagate ST31000528AS 1TB 7200.12, no spin, not recognize
PostPosted: September 17th, 2017, 15:29
you should have post the log prior to:
F3 2>Z // first line from the code YOU posted
PostPosted: September 17th, 2017, 15:36
This is my entire session
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/2
F3 2>Z
ExecuteSpinRequest
DiagError 00006002
F3 2>U
ExecuteSpinRequest
DiagError 00006008
Spin Error
F3 2>Z
Spin Down Complete
F3 2>U
ExecuteSpinRequest
ExecuteSpinRequest
DiagError 00006008
Spin Error
F3 2>Z
Spin Down Complete
Elapsed Time 0.103 msecs
F3 2>
Spinning Down
Spin Down Complete
Elapsed Time 0.091 msecs
Delaying 5000 msec
Jumping to Power On Resetâ–’
Rst 0x20M
ASCII Diag mode
F3 T>/2
F3 2>Z
ExecuteSpinRequest
DiagError 00006002
F3 2>U
ExecuteSpinRequest
DiagError 00006008
Spin Error
F3 2>Z
Spin Down Complete
Elapsed Time 0.106 msecs
F3 2>U
ExecuteSpinRequest
ExecuteSpinRequest
DiagError 00006008
Spin Error
F3 2>
Spinning Down
Spin Down Complete
Elapsed Time 0.099 msecs
Delaying 5000 msec
Rst 0x20M
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/2
F3 2>Z
ExecuteSpinRequest
DiagError 00006002
F3 2>U
ExecuteSpinRequest
DiagError 00006008
Spin Error
F3 2>Z
Spin Down Complete
Elapsed Time 0.097 msecs
F3 2>U
ExecuteSpinRequest
ExecuteSpinRequest
DiagError 00006008
Spin Error
F3 2>/1
PostPosted: September 17th, 2017, 16:42
Are you sure that there are no sounds coming from the drive? Could there be a stiction fault or seized spindle motor?
If you have a multimeter, can you detect any voltage pulses at the motor terminals? What are the resistances between each pair of motor terminals?
Does the motor controller IC become hot?
PostPosted: September 17th, 2017, 17:58
Thanks for the help. The drive really does not make any sound that I can hear.
On defective drive, IC's are warm to touch where I indicated in attached photo. 0 resistance and 0 voltage at motor terminals where measured in photo. Tested between all 3 terminals.
(BTW, as a sanity check, I measured motor terminals on a good drive and got 300 ohm and between 5 -15 milli volts on the good drive, not sure what range is to be expected)
Defective board looks kinda discolored to me at the 2 warm points, even more to the naked eye than in the photo.
File comment: Defective 7200.12
PostPosted: September 17th, 2017, 18:41
The resistances between each pair of terminals should be the same and should be of the order of 1 or 2 ohms. I don't know why your good drive is showing 300 ohms. Are you measuring the resistance with power off?
The voltages at each terminal should be pulsing immediately after the spin-up command. The pulses should stop after 5.397 secs.
Is the good drive the same model? If so, does its PCB spin up your patient?
Users browsing this forum: No registered users and 65 guests
