 Post subject: Micro USB replacement for wd3200bmvv
PostPosted: September 6th, 2017, 21:01
I've got an old WD passport wd3200bmvv. PCB on this model has integrated micro usb port which is damaged. I see replacement PCB's available for around $50 but it seems like a fairly trivial soldering job to just replace the damaged USB port itself rather than purchase a whole new PCB and do a ROM swap. Mouser has a bunch of different ports listed here
http://www.mouser.com/Connectors/USB-Connectors/_/N-88hmf?P=1yzxjxdZ1z0yy6bZ1yzudq8Z1ytavvn but none are an exact visual match. Anyone know which is a suitable replacement? Or is there another source?
Thanks!
 Post subject: Re: Micro USB replacement for wd3200bmvv
PostPosted: September 6th, 2017, 21:14
eBay is what I use mostly. I buy packs of each type. MUCH cheaper usually, but actually if I need something relatively cheap, I look for the fastest I can get it, not the cheapest or easiest.
for HDDs with a damaged port, I would solder wires to any USB header, get the data and buy a new drive. I never trust hdd's with any physical damage after recovery. Ever.
PostPosted: September 6th, 2017, 21:20
Cut the end off a USB cable and solder the wires directly to the PCB?
PostPosted: September 6th, 2017, 21:24
When I need a part I can't find browsing through online catalogues, I contact Digi-Key's technical sales rep and provide pictures of the part. They are really helpful at finding just the right part.
PostPosted: September 20th, 2017, 0:49
I like this idea but the traces where the damaged port were are too small...
See pics.
PostPosted: September 20th, 2017, 10:35
you solder stuff like that under a stereo microscope, it is quite easy to do. for the wire to USB header method, you can use thin kynar wrapping wire at around AWG#30 or less. also if the header is not an exact match physically, it doesn't matter. A data recovery company should have all the tools and shouldn't cost that much as long as there are no other issues.. if you cant find a friend to do it.
PostPosted: September 20th, 2017, 16:48
Solved this one. I was able to locate a similar PCB from an older Passport drive, remove the USB port with hot air, and then resolder onto the damaged PCB with micro pencil tip. Thanks for all the tips.
PostPosted: September 20th, 2017, 18:06
great result, well done. I would be getting data off and not using the drive again.
Users browsing this forum: Google [Bot], mima85 and 66 guests
