 Post subject: deleted files on HFS+ partition
PostPosted: September 27th, 2017, 6:04
what is the best tool to recover deleted files on HFS+ partition?
On this case, the user deleted by mistake a folder with pictures and after that didn“t touch anymore on the disk.
I already tried PC3000, R-studio, UFS and Reclaime (all under windows OS) and cannot find the folder neither the pictures on the RAW recovery.
Any help will be appreciate.
 Post subject: Re: deleted files on HFS+ partition
PostPosted: September 27th, 2017, 7:33
Is this an SSD drive or traditional hard drive?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 27th, 2017, 7:50
SSD drive from a MAC
PostPosted: September 27th, 2017, 8:50
You can try Data Rescue 4. Have it scan just the unallocated areas of the drive. You might find something, but it will be a RAW recovery of it. HFS+ and SSD. deleted data will be very hard to get back.
PostPosted: September 27th, 2017, 9:39
Game over, if trim was enabled you will not get data back.
PostPosted: September 27th, 2017, 10:20
Thanks digisupport. Game over
PostPosted: September 27th, 2017, 21:23
I want to learn from others' experiences -- what happened because Trim was enabled?
"Take care of thy backups and thy restores shall take care of thee." Ben Franklin revisited
PostPosted: September 28th, 2017, 1:59
This should help. " ...inform a solid-state drive (SSD) which blocks of data are no longer considered in use and can be wiped internally"
Blizzard Data Recovery
PostPosted: September 28th, 2017, 4:51
RolandJS please read: www.datanumen.com/blogs/possible-recove ... ate-drive/
PostPosted: September 28th, 2017, 20:53
Thanks all! I understand much better now.
Users browsing this forum: No registered users and 63 guests
