Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: WD20NMVW-11EDZS7
PostPosted: October 5th, 2017, 10:39
Hello!
The drive in topic shows all sectors ABRT. All modules backed up OK with no error.
After replacing heads the same problem. Back original heads the same problem.
Any thoughts what's the problem?
Thanks in advance.
 Post subject: Re: WD20NMVW-11EDZS7
PostPosted: October 5th, 2017, 13:16
P/W locked?
http://www.rescue-it.se
PostPosted: October 5th, 2017, 14:28
No Password and not a translator issue either.
thanks for replies.
Any other thoughts, please?
PostPosted: October 5th, 2017, 14:33
What is the customer's story on what caused the drive to fail? Also, did anybody else work on the drive prior to arriving to you?
PostPosted: October 5th, 2017, 15:01
As you know, all customers lies. He didn't tell me anything (but the top cover didn't opened before).
My diagnosis from the beginning:
It's USB drive (Shrek LT) spin up normally (not detected) Slow responding and/or bad head/s.
Converted to SATA (MRT never see it's family and no SA access) after some workaround I can backup all mods. and ROM.
After modifying mod 127 MRT can auto detect SA and mod dir.
I can access SA but no access user area (ABRT). (with patient heads and donor heads).
SO, what do you think?
Thanks in advance.
PostPosted: October 5th, 2017, 15:28
Isn't that where the password would be stored?
PostPosted: October 5th, 2017, 17:38
That's right. For enable/disable SA access too.
Spildit wrote:
- Original ROM modules / head map and active directory of ROM modules.
Checked OK.
Spildit wrote:
- Restore original 127 after patching 02 for disable background media scan.
Already done with no luck.
Spildit wrote:
- If you have PC3K most likely you can decrypt/bypass the encryption.
I don't think it would be the problem. (by the way it's encrypted with aSmedia)
Spildit wrote:
- There might be a problem with encryption keys locking access the LBA.
I think if there's a problem with key the drive will scan normally with encrypted data not ABRT.
Spildit wrote:
And as your forum name sugests .... other possible causes for drive not to allow access to LBA are ... @unknown
You are right until now. Problem still unknown. :D
PostPosted: October 5th, 2017, 18:13
Sure, but when telling them that you need to understand what happened originally, so you can actually resolve the problem, therefore preventing billable hours/fees, then they will start talking. Telling what happened is in his best interest, no? Otherwise, there is no recovery happening.
PostPosted: October 6th, 2017, 15:13
Yep, we find that in 9/10 times the customer lies about what happened.
So sadly, we have to assume in all cases the the customer is lying about everything until proven otherwise.
Sad but true :-(
PostPosted: October 6th, 2017, 16:18
The customer swear he was working on win 10 then unplug the drive then after a while he replug it again and the drive fail. That's all.
PostPosted: October 6th, 2017, 18:59
Ah, but :
Why did he unplug the drive and reconnect it after some (little ? ) time ? Maybe because his computer was experiencing some problem ?
Also, did he stop/eject the drive through windows, or just disconnect the cable ?
PostPosted: October 7th, 2017, 11:16
Try to disable the SED crypto-engine all together (in module 02) and see if you can read the sectors after that.
If you can then that means the crypto-engine is not initialized properly, it happens sometimes.
PostPosted: October 7th, 2017, 16:04
rogfanther wrote:
Ah, but :
I think this won't make a difference.
Thanks for reply.
I will try and post the results.
Thank you.
PostPosted: October 7th, 2017, 17:51
Unfortunately, no luck. I am trying from another method.
PostPosted: October 7th, 2017, 19:54
Could the ASMedia bridge be functionally and electrically equivalent to JMicron's JMS569? The latter does not support encryption.
What is the bridge part number? PCB part number? USB VID/PID?
I have collated various data here:
http://www.hddoracle.com/viewtopic.php?f=7&t=1404&p=10066
PostPosted: October 7th, 2017, 21:46
There is no encryption by ASMedia
Encryption is done by the drive itself
PostPosted: October 7th, 2017, 22:44
If you follow my link to the HDD Oracle thread, you'll see the reason for my question. AIUI, WD has employed at least two different approaches to USB-connected SEDs, and these approaches are related to the type of non-encrypting bridge used.
PostPosted: October 8th, 2017, 0:01
I don't understand what you mean by "two different approaches"
But ASMedia does no encryption, it's been checked
PostPosted: October 8th, 2017, 0:05
Did you follow my link?
PostPosted: October 8th, 2017, 9:43
unknown wrote:
Hello!
Thanks in advance.
SED.
Users browsing this forum: Google [Bot] and 249 guests
