 Post subject: Help with a non accessible Hitachi HDD Drive
PostPosted: October 11th, 2017, 16:32
I would like to rescue Data from a defective Hitachi HDD which does not show up anymore in Bios or OS.
The HDD Model is Hitachi 5k750.
When I connect the HDD to the power source I can hear normal spin up of the motor and first head activity.
I have access to the exact same model of the HDD (same Type ID, Firmware, same MLC code etc, only diffrence is the serial number), and was wondering if switching their pcb would help get access to the data. I did this type of switching a decade ago with an IDE Drive and it worked out well but I don't know if the rules have changed with modern SATA drives.
I read somewehere that in addition to PCB exchange, I also need to exchange the ROM chip containing calibration Data which is unique for every HDD. Is this info correct?
Thanks in advance for any help/guide/info.
Greets,
Cesarius
 Post subject: Re: Help with a non accessible Hitachi HDD Drive
PostPosted: October 11th, 2017, 16:47
No, you can´t and shouldn´t just replace the board on this one. There are hitachi models where starting the hdd with a different board and eeprom will affect the data , and may make the recovery much more costly.
You would need to swap the rom chip, yes, but first you should identify if the problem is really the board. Has the disk suffered some power surge, etc ? Any burnt signs ?
PostPosted: October 11th, 2017, 16:53
No Power surge but physical shock while running.:( Sorry just got the info from my friend for whom I am trying to rescue the data.
PostPosted: October 11th, 2017, 17:33
99% sure it is not a PCB problem. Think about it: how could electronics get damaged as result of physical shock while running?
It is internal mechanism problem, typically heads.
PostPosted: October 12th, 2017, 13:52
Absolutely agree
PostPosted: October 14th, 2017, 19:03
I'm a newbie learner here, does the situation now call for a data recovery company / specialist with a clean-room?
"Take care of thy backups and thy restores shall take care of thee." Ben Franklin revisited
PostPosted: October 15th, 2017, 1:52
if the Data is important COnsult with Professionals, might be Head Stuck only which can be done with basic charges if you keep experimenting on it condition might get worse & cost you more money .....
Users browsing this forum: No registered users and 287 guests
