 Post subject: Donor drive WD3200BEVT-22ZCT0 wanted
PostPosted: October 12th, 2017, 7:12
Hi
I'm looking for a good donordrive for a headswap:
WD3200BEVT-22ZCT0
Date: 04 may 2008
DCM: HBCVJBBB
PCB: 2060-701499-000 REV A
second PCB (on sticker): 2061-701499-500 AA
According to PC3000 head 0 and 1 are defect. One of the heads was stuck and i got i lose without damaging the platter but i think the heads were damaged (not visible under microscope)
Hope someone can help me out :)
 Post subject: Re: Donor drive WD3200BEVT-22ZCT0 wanted
PostPosted: October 15th, 2017, 2:16
hi,
what happens when you power on as you said Heads are good (you had checked in microscope) power Drive & check Hard Drive Behavior....
PostPosted: October 18th, 2017, 10:41
I bet there are a couple of those out there on ebay.
Or if you wanna outsource we can help in that.
PostPosted: October 18th, 2017, 14:10
lifeguarddubai wrote:
hi,
Heads are not good. Heads 0 and 1 are probably defect. When i do a headmapping in RAM with pc3000 UDMA the headstack make different kind of noices but nothing is been read. So i guess the most effective solution will be a complete headstack with a donordrive and exact same specifications.
Users browsing this forum: No registered users and 263 guests
