 Post subject: Any way to connect TEAC SD-3250N to PC with USB adapter?
PostPosted: October 11th, 2017, 5:15
Where to buy?)
 Post subject: Re: Any way to connect TEAC SD-3250N to PC with USB adapter?
PostPosted: October 12th, 2017, 2:48
http://www.ebay.com/itm/TEAC-SD-3250N-3 ... 2440804534
or check ebay
you can try with http://www.ebay.com/bhp/ide-to-sata-converter ide to sata
http://www.ebay.com/bhp/ide-to-usb ide to usb
PostPosted: October 16th, 2017, 6:38
i can`t cause it`s specific connector, will post pic later
PostPosted: October 16th, 2017, 12:00
It appears that the drive in jerovsek's eBay link comes with a 40-pin IDE interface adapter. I don't know if they ship extraterrestially, though.
PostPosted: October 16th, 2017, 17:27
Well, if the drive was scavenged from a broken Mars Rover, maybe he should call NASA and see if they have a spare ?
PostPosted: October 17th, 2017, 1:31
http://www.mhill.co.kr/shop/shopdetail. ... uid=416064
PostPosted: March 25th, 2018, 2:23
this is the connector i have on this hdd
PostPosted: March 25th, 2018, 2:38
Mon Oct 16, 2017 9:38 pm:
Sun Mar 25, 2018 5:23 pm:
That took 5 months. Did you bring it back to Earth with you?
Seriously, you should try to purchase the adapter alluded to earlier.
http://www.acelab.ru/dep.pc/doc.pc3000dos/050530.001/PCTEAC.pdf
PostPosted: March 26th, 2018, 1:09
Some photos ...
http://www.rom.by/comment/260189
PostPosted: March 29th, 2018, 11:01
jerovsek wrote:
http://www.mhill.co.kr/shop/shopdetail.html?branduid=416064
This is clearly the adapter you need. It is also commonly used for cd/dvd drives so you can probably use an adapter designed for those drives as well, which may be more common on ebay, et al.
From that point, all you need is an IDE to USB adapter cable or IDE USB external enclosure for the drive.
Users browsing this forum: Google [Bot] and 72 guests
