 Post subject: Need ROM Sadle G6 WD10EARS-00MVWB0.
PostPosted: November 8th, 2017, 12:55
Hello all,
if one of you had a ROM available with these adaptives would be great and I will thank you eternally.
Model - Sadle G6 WD10EARS-00MVWB0
ROM VERSION 25.12e
Headmap 0256
Thanks again!
 Post subject: Re: Need ROM Sadle G6 WD10EARS-00MVWB0.
PostPosted: November 8th, 2017, 19:15
What's the consolidated ROM version?
00250012 I presume?
If so, here it is: http://gofile.me/6nc9a/Nt06H6yGh
PostPosted: November 8th, 2017, 20:08
The headmap of the one I posted is different, but it includes all those heads, so maybe you can just disable the ones you don't need... :?
PostPosted: November 8th, 2017, 21:44
I think this should work, I will try tomorrow when I get into the office. Thank you so much.
I would expect the headmap to be different. The drive is marked as a 1TB model but everything I can see matches up to the 2TB model including the heads I used for donors. I believe this drive was originally a 2TB refurbed into a 1TB from the factory and they physically disabled some heads.
I will be sure to update you tommorow as to my results. Thanks again!
Users browsing this forum: Bing [Bot] and 225 guests
