 Post subject: Segate 7200.12 Illegal condition
PostPosted: November 20th, 2017, 14:44
Segate
ST31000524AS
Firmware: JC4B
DateCode:12177 Site Code SU
Trying to get an image of this drive, thus far unsuccessfully.
When i plug it in (power and sata) i get exactly 11 clicks, then DMESG starts to show attempts to interface with it. After many failures and attempts to negotiate at lower and lower speeds it identifies as a ATA-6: ST_M13FQBL.
Most times it will not be able to list capacity at all, but once or twice it showed up at 4.1GB. I tried to image this and got 4.1GB worth of i/o errors. Curiously it seems to read SMART and show 1 bad sector.
When i connect to UART i get
Boot 0x20M
Spin Up
(then after around a minute)
Illegal condition encountered.
I cannot interact via UART, CTR Z does nothing
I suspect it will likely come down to a head issue, but the number of firmware updates that were released for this series has me wondering if there is a possible firmware issue.
I have never seen "Illegal condition encountered." before, and can find no other reference to anyone else ever seeing it either.
any thoughts?
thank you as always
 Post subject: Re: Segate 7200.12 Illegal condition
PostPosted: November 20th, 2017, 14:55
11 clicks and spin down = bad heads
PostPosted: November 20th, 2017, 14:58
+1. Don't keep booting the drive to try to read it you will be causing more damage. You need to seek professional data recovery help.
PostPosted: November 20th, 2017, 15:08
Ok, thank you for the confirmation.
If anyone wants to toss their hat into the ring here with a quote/estimate via PM i am listening.
PostPosted: November 20th, 2017, 19:57
If there's no rings on the platters, our rate is typically $650 + cost of the donor drive we need to pull the heads from. But, lately I've been seeing a lot of 7200.12's that have the platters just destroyed with scratches.
PostPosted: November 21st, 2017, 3:11
Our pricing is similar, and in most cases one platter surface is damaged in these drives.
PostPosted: November 22nd, 2017, 8:52
Agree with Pcimage almost all cases one of the surface have scratch..............
PostPosted: November 23rd, 2017, 6:19
This is totally overpriced, $650.
We could do it for $350.
PostPosted: November 23rd, 2017, 9:23
Say's the man with 1 post...
http://www.rescue-it.se
PostPosted: November 23rd, 2017, 11:40
What's your location, please? I may be able to refer some clients who fall within your rate.
PostPosted: November 30th, 2017, 19:08
It's not the end of the world if it has rings...
done several with such damage.
Users browsing this forum: Google [Bot] and 315 guests
