 Post subject: ST380013AS
PostPosted: November 21st, 2017, 8:33
Hi
I got SEAGATE BARRACUDA ST380013AS it gets ready and Drive ID is full and correct When I do sector edit or enter any command hdd is busy. Terminal window is:
 Post subject: Re: ST380013AS
PostPosted: November 21st, 2017, 8:34
What is do hdd reboot? and What is meaning wrong in terminal?
PostPosted: November 21st, 2017, 10:09
Have you tried to do a headmap and select each one and test?
Seems to be a bad head...
ACELab partner
PostPosted: November 22nd, 2017, 2:36
Agree with Split Heads seems bad,
try swap Donor Heads before that try using Seagate Utility while creating Task with LDR..
PostPosted: November 23rd, 2017, 7:55
Firstly, Thanks a lot for response. İn this case, PC 3000 dont allow creating head map. I saw HDD ID and SERIAL Number. But If I want to read sector But HDD can read so little sector then HDD stoped. Dırectly, Before that I swap head from donor disk to patient disk. What should I do?
PostPosted: November 23rd, 2017, 11:42
Can test heads manually in terminal. Check manual on how.
PostPosted: November 28th, 2017, 14:21
It can be a pending issue with bad heads. Create a task with active utility actions, and try to solve the pending issue with head map changing at once.
