 Post subject: Issues with a Red WD30EFRX-68AX9N0
PostPosted: November 10th, 2017, 11:47
Drive comes ready on normal mode but does not ID correct.
Model : WDC WD30EFRX-68AX9N0
Serial : WDC-ROM SN# XYZ----
Firmware : 80.00A80
Capacity : 0 MB (!) (1)
Heads number............................ : 6
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 1714
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 235 833
Module 02 access........................ : Granted
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 04.27B
ROM F/W version......................... : 00040027
Overlay F/W version..................... : 04.28B
Servo F/W version....................... : 05.2V
Heads configuration..................... : by map
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 0,1,2,3,4,5
Service area:
Permanent overlay....................... : Loaded
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
All modules modules were saved with no errors on any of the copies, tried to rebuild translator and I get this failed message
Translator regeneration
Regeneration method..................... : Use P-List only
P-List Copy 0........................... : Ok
P-List Copy 1........................... : Ok
Translator regeneration error Device Error Detected: "FM ERR CHECKSUM"
I swapped the PCB just to make sure is nothing wrong with it and rebuild ROM from SA, wrote the ROM to a new ROM chip also and still have the same error message when trying to rebuild translator
Any ideas please...
TIA
 Post subject: Re: Issues with a Red WD30EFRX-68AX9N0
PostPosted: November 10th, 2017, 12:41
Firmware : 80.00A80
ROM:
ROM Modules:
Service area:
Any ideas please...
TIA
Is a SA Structure Test All OK Or You Have Some Checksum Issues In Few Modules ? .
PostPosted: November 10th, 2017, 12:48
Thank you Amarbir, but I had checksum all modules already this morning and all checks good even ROM modules checked ok. Kind of baffle :?
PostPosted: November 10th, 2017, 13:09
Well,
i will pm you in morning i have one thing in my brain
PostPosted: November 10th, 2017, 13:16
thank you, have a good night :cool:
PostPosted: November 11th, 2017, 3:03
Send Me a Request on Skype on lynx-india
PostPosted: November 15th, 2017, 19:11
it's Case of Undetected HDD , u have 0 MB HDD
this error have many Reason like key Modules Corruption , Bad Sector in SA , ROM Corruption , ...
Can Solved Online , you Can Try with Amarbir .
and Update Here
http://www.hpwlab.com
PostPosted: November 15th, 2017, 19:15
That one thing more than normal :P :P :P
PostPosted: November 16th, 2017, 11:27
and Update Here
I was not contacted yet ,I had solved a few cases like this few times
PostPosted: November 27th, 2017, 16:57
Head swap fixed the issue
Users browsing this forum: Google [Bot] and 69 guests
