 Post subject: Toshiba MQ01ABF050 Questions
PostPosted: December 19th, 2017, 9:47
I have a Toshiba HDD that wont spin correct. There are no clicking-sounds, the Drive just Spins up a Little Bit and then spins down immediately. I have checked the Voltage at PJ801. 5v and ground.
The PCB itself looks fine, no burnt spots or missing components. Can anybody give me a tip to bring this drive back to live? Soldering is no problem. Do i have to order a Donor-PCB or is there a chance to get around ordering one? It would be fine to Recover the data from this HDD.
Hope to get some help...
Menz
 Post subject: Re: Toshiba MQ01ABF050 Questions
PostPosted: December 19th, 2017, 10:44
Buy new board and resolder ROM (IC602).
Backup is Your best friend. Still learning English. Sorry for language bugs. My websites: Centrum Odzyskiwania Danych
PostPosted: December 19th, 2017, 11:30
Which Parameters dp i have to check?
I have the following Numbers:
PCB is G003235C
MQ01ABF050
ABM AA00/AM0C5E
Is it just the PCB Number that have to match when i order the replacement-PCB or do i have to check any other number?
Thank you,
Menz
PostPosted: December 19th, 2017, 12:05
Just PCB number
odzyskiwanie danych
PostPosted: December 19th, 2017, 12:17
If the drive spins up and spins down is a clear sign the issue is the heads (even media damage already) and nothing wrong with the pcb, contact a real DR company will be the only chance to recover your data
PostPosted: December 19th, 2017, 15:16
I have seen these with dodgy PCB’s that cause erratic spinup and spin down.
PostPosted: December 19th, 2017, 15:44
What is that fleck over the "S" in the "TLS2605" marking on the motor controller (IC102)?
PostPosted: December 19th, 2017, 15:46
Looks like a scorch mark to me
PostPosted: December 19th, 2017, 15:55
If 602 was burnt out, drive would be dead
Edit: ah 102 lol
https://www.mjm.co.uk/
PostPosted: December 19th, 2017, 17:02
Isn't the circuit above burned as well...or is it just glitch in the picture?
http://www.rescue-it.se
PostPosted: December 19th, 2017, 17:12
Are you referring to the 16-pin shock sensor amplifier (BD3851)?
PostPosted: December 19th, 2017, 17:21
The thing in IC102 looks a hole to me, also.
Maybe a piece of dust, or glue residue ?
PostPosted: December 19th, 2017, 17:35
There is a little Particle on TLS2605, nothing to worry about.
Any further tips? I can assure you that nothing is burnt or missing.
Maybe we can find a solution ;-)
Menz
PostPosted: December 19th, 2017, 18:49
Yep
PostPosted: December 19th, 2017, 18:58
Menz
Good.
As stated, you need a board same model number, and transfer IC602 to the bad board to the new one.
Or, if data is important, send the drive to some specialized
PostPosted: December 19th, 2017, 19:16
But which seller should I use to order the Replacement PCB? Is hddzone.com reliable?
PostPosted: December 19th, 2017, 19:55
The bottom motor pins look strange..cold solder joint?
PostPosted: December 20th, 2017, 2:33
check ebay
https://www.ebay.de/sch/i.html?_odkw=G003235C&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XMQ01ABF050.TRS0&_nkw=MQ01ABF050&_sacat=0
PostPosted: December 20th, 2017, 8:45
Motor Pins checked, no cold solder joints.
PostPosted: December 20th, 2017, 10:56
Data recovery should start from simplest work. Replacing the PCB is simple. If it do not help then You need to find DR company.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 209 guests
