Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Dead Kingston M.2
PostPosted: January 23rd, 2018, 17:39
Is the Vcc supply present at each of the Enpirion regulator ICs? If not, are their Vcc pins sitting at 0.69V?
Are the T3m0J parts connected in parallel, ie is pin #1 connected to pin #1, pin #2 to pin #2, etc? If so, then I suspect that these parts may be P-channel MOSFETs or PNP BJTs operating as a 3.3V power switch. The B-E voltage is 0, so these switches would be off. Does pin #2 connect to the Enpirion Vcc pins?
PostPosted: January 23rd, 2018, 18:32
This is just a guess, so I could be completely wrong ...
         VCC = +3.3V
     |    G | S|    G|       off = +3.3V
   S +-||---'  +-||--+----<  on = 0V
     <-|| T3   <-||  T3
   D +-||    D +-||  2 x P-ch MOSFETs
          |      switched VCC
          o----> to regulators
       |AC-V |----> /Reset to controller
         GND
PostPosted: January 23rd, 2018, 19:24
Both logic ICs appear to be working correctly.
PostPosted: January 23rd, 2018, 19:46
What is the voltage on pin #38 of the M.2 SATA Connector?
    pin #38 - DEVSLP (I)(0/3.3V)
Device Sleep, Input when driven high, the host is informing the SSD to enter a low power state
Does this interface pin drive the gate terminal of the T3 MOSFETs, perhaps via a series resistor?
PostPosted: January 24th, 2018, 3:00
Yes, all the ICs have 0,69V on their Vin and the Vout is 0V.
Yes, you are right, all the T3m0J is in parallel.
PostPosted: January 24th, 2018, 3:02
Really hard to reach the lower pins in this little dock that I have.
The upper row I can reach by pulling the M.2 out a bit, but the row underneath is hard to reach.
PostPosted: January 24th, 2018, 4:06
I had a look on the back side and followed the circuit.
Pin 38 looks goes according to the picture. I made an overlay of front and back to see where it goes and it seems to match.
One thing that doesnt make sense is that I cant measure any contact between those two points. Guess its many layers in the PCB.
Edit: Forgot to mention that the solder point on the front side where it looks to be connected is at 3.3V.
PostPosted: January 24th, 2018, 5:15
No, you are having a brain fart. :-)
The photo of the underside counts from pin #2 whereas the component side counts from pin #75, ie you are comparing opposite ends of the PCB.
PostPosted: January 24th, 2018, 10:55
Oh, yes, you are right..Sorry :)
This should be correct. And this time I have connection between pin 38 and the component.
The thing is that it looks to be 3V. Should I try grounding it?
PostPosted: January 24th, 2018, 14:19
Can you check whether there is any continuity between pin #38 and the T3 MOSFET switches?
Grounding pin #38 would seem like the thing to do, but I would like to know more about your dock/adapter. In particular, why would the dock be putting the SSD to sleep?
PostPosted: January 24th, 2018, 15:00
#38 -> Pin 1 = 58,8 kohm
#38 -> Pin 2 = 34,4 kohm
#38 -> Pin 3 = 11,6 kohm
This is a M.2 -> USB dock. I will get USB->SATA tomorrow to see if there is any difference.
I doubt that the 3V at pin #38 is comming from the adapter. I isolated the pin from the adapter, but it was still 3V.
When grounding pin #38, the adapter shut down.
PostPosted: January 24th, 2018, 15:26
DEVSLP is an input to the SSD and an output from the adapter. Are you sure that pin#38 is not directly connected to Vcc, either on the adapter or on the SSD? That would explain the shutdown.
PostPosted: January 24th, 2018, 16:26
I Will get a M.2 -> SATA adapter tomorrow and see if it is any difference.
(Not USB->SATA as I wrote earlier!)
PostPosted: January 25th, 2018, 9:30
Actually the pin 11 could be used both ways. It can be used for staggered spin-up as you said, and in the other direction it can be used to signal the Activity LED.
https://en.wikipedia.org/wiki/Serial_ATA
(But I don't know what the SSD we are talking about here actually does with it)
PostPosted: January 25th, 2018, 15:16
Pin 10 is DAS/DSS# (I/O). We are talking about a 75-pin M.2 interface, not 22-pin SATA. DEVSLP is a different signal. In any case I would think that the MCU would need to be alive in order to respond to DSS#. That is, DSS# should not directly control the power. But ICBW.
PostPosted: January 26th, 2018, 10:45
Oops, sorry. Ok, then please ignore my completely irrelevant comment above.
PostPosted: January 27th, 2018, 0:38
The SATA spec was updated to include a DEVSLP/PWDIS function on SATA power pin #3.
Power Disable Feature (SATA 3.2+ / 3.3):
http://www.hddoracle.com/viewtopic.php?f=42&t=2094&p=13846
A standard SATA power cable incorporates 3.3V wires on pins 1 to 3. Unfortunately PWDIS/DEVSLP was defined in such a way that the presence of 3.3V on P3 disables power to the device. The workaround is to cut the 3.3V wires from the SATA cable.
Here is a product which illustrates this:
http://www.microsatacables.com/sata-iii-to-m2-ssd-adapter-device-sleep-mode-devslp-m2-devslp-pcb
http://www.microsatacables.com/media/catalog/product/cache/1/image/650x/040ec09b1e35df139433887a97daa66f/a/d/ad909a_-_device_sleep_devslp_.jpg
PostPosted: January 27th, 2018, 10:20
Im starting to give up on this.
Been trying to understand this but cant get it to work.
I've tried to short pin 38, but there is no difference.
Here is a picture of how some things are connected.. dont know if its for some help.
PostPosted: January 27th, 2018, 15:56
I think we are very close to a solution.
Pin #38 would be directly connected to power pin P3 (+3.3V) of your SATA cable. If you short this pin to ground, without doing anything else, then you will be shorting your SATA power source. Instead I would flow a blob of solder between pins 2 & 3 of C35.
I'll post a diagram of this area of the circuit shortly.
PostPosted: January 27th, 2018, 17:22
                          VCC
                           +           VCC
      ___   |   __      |  |            |
LO --|___|-----\  \     |--'        .-------.
      ___   |   |  |o-. |           |       |
LO --|___|-----/__/   | |           | VLAN  |
         .--|   CB5   | | HI          |   |
         |  |   NOR   '----.          |   | HI
        ===                |         GND  |
        GND                |              |
          | |            | HI  |
       HI '---..---------|-----'  VCC
            | ||  __     |         +
      |     | .--|__/  | |
      |     | |        | |    ___
      |   .---'  C35   '-|---|___|--> to T3 gates?
     ===  | |    AND     |
     GND  | '------------'   +3.3V = power OFF
          |                     0V = power ON
     ___  |
  o-|___|-'
  DEVSLP
  M.2 pin #38
  +3.3V = power disable
     0V = power enable
Users browsing this forum: Bing [Bot], Google [Bot] and 225 guests
