 Post subject: Accidentally cloned HDD
PostPosted: February 16th, 2018, 4:18
Hi everyone.
A couple of days ago accidentally i cloned the wrong HDD using Acronis and for days now i m running different data recovery software's without any success, the only i can get it is the OP. My lost data it is around 180 GB. The HDD it is WDC320. I m listening for any ideas or suggestions that i can try, any help it is welcomed.
Thank u.
 Post subject: Re: Accidentally cloned HDD
PostPosted: February 16th, 2018, 17:13
Well, first describe the size of the hdd you cloned from. Depending on the size of it, it could have overwritten all of the problem hdd.
Also, what software have you tried ?
PostPosted: February 17th, 2018, 1:13
Size of the HDD that was cloned from it is also 320.
That s a short list of software i used:
Wondershare
Spotmau
EasyRecov6
Restorer Ultimate Orig
GeeksnerdsDataRecoveryFull
Runtime Software Data Recovery Drive
Stellar Data Recovery
...and some others, but i have the feeling that yes the Hdd was indeed overwritten all.
PostPosted: February 17th, 2018, 7:45
Depending on the amount of data in the source hdd, most of the data in the affected hdd would be overwritten.
Have you tried R-Studio ? Probably, at this point, you can only get some files with file carving, and not the original folder structure and file names.
PostPosted: February 17th, 2018, 8:24
If you cloned a 320 to a 320...there is nothing left...sorry to say.
http://www.rescue-it.se
PostPosted: February 17th, 2018, 11:51
In older versions I used the default for Acronis is copy used sectors only to increase speed. If you wanted a true sector-by-sector clone you would have to select the "back up sector-by-sector" checkbox. For command line operations you would have to specify /raw.
Blizzard Data Recovery
PostPosted: February 17th, 2018, 14:01
...anyway without luck...but thanks for advise for all of you.
Users browsing this forum: No registered users and 125 guests
