Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
 Post subject: Re: RoseWood
PostPosted: March 1st, 2018, 7:26
@ Unknown , You are more than welcome any time Dear :horse:
:druunk:
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: March 1st, 2018, 9:24
Tawfeek, Thank you my friend.
100% data recovered. (60 GB) :wink:
PostPosted: March 1st, 2018, 11:17
unknown wrote:
@ Doomer
Unfortunately, I will continue doing data recovery. :mrgreen:
Yes, that's unfortunate
PostPosted: March 1st, 2018, 11:18
I doubt that very much, considering that all latest data that was in MC was wiped clean once you racalced translator
PostPosted: March 1st, 2018, 11:30
Why should I lie?
What proof do you need?
I don't know why are you so offensive to me and like you take it personally?
PostPosted: March 1st, 2018, 11:38
unknown wrote:
Why should I lie?
you don't lie
you simple don't understand and as I said before, that's is unfortunate, for your clients of course.
PostPosted: March 1st, 2018, 11:41
Discussion ends here. As the case is solved already.
Thanks for anyone tried to help.
Good luck.
PostPosted: March 1st, 2018, 13:27
i like this part . :smokers:
Tawfeek Mokhtar
PostPosted: March 1st, 2018, 17:05
copying 100% of the files does not mean they contain the data they should. This is the bad thing with clearing MC. It should be avoided where possible.
PostPosted: March 1st, 2018, 17:23
~60 GB of Pics and Videos are tested and working.
But you are totally right. This time I was lucky enough to get the data.
Next time I will think several thousands times before messing with rosewood with my limited tools and knowledge.
PostPosted: March 4th, 2019, 12:55
i can solve this problem
PostPosted: March 4th, 2019, 13:06
unknown wrote:
Hello
ST1000LM035
SBM3
1 TB
The drive in topic shows correct ID, capacity and FW then stuck in busy and no user area access.
Terminal output:
Boot 0x80M
QB
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 000015F4 At SU: 00004888 NT: 0000000A OT: 0000000E
(POR) Recover Secondary MCMT Opened Recovered
(MC POR Duration): 0000000146
Send Status: COMRESET seen
CSpd= 6Gbps
Update Mask - 0000000006196520 - 00000008 - 00
Update Mask - 0000000006196528 - 00000008 - 00
Update Mask - 0000000006196530 - 00000008 - 00
Update Mask - 0000000006196538 - 00000008 - 00
Update Mask - 0000000006196540 - 00000008 - 00
Update Mask - 0000000006196548 - 00000008 - 00
Update Mask - 0000000006196550 - 00000008 - 00
Update Mask - 0000000006196558 - 00000008 - 00
Update Mask - 0000000006196560 - 00000008 - 00
Update Mask - 0000000006196568 - 00000008 - 00
Update Mask - 0000000006196570 - 00000008 - 00
Update Mask - 0000000006196670 - 00000008 - 00
Update Mask - 0000000006196678 - 00000008 - 00
Update Mask - 0000000006196680 - 00000008 - 00
Update Mask - 0000000006196688 - 00000008 - 00
Update Mask - 0000000006196690 - 00000008 - 00
Update Mask - 0000000006196698 - 00000008 - 00
Update Mask - 00000000061966A0 - 00000008 - 00
Update Mask - 00000000061966A8 - 00000008 - 00
Update Mask - 00000000061966B0 - 00000008 - 00
Update Mask - 00000000061966B8 - 00000008 - 00
Update Mask - 00000000061966C0 - 00000008 - 00
Update Mask - 00000000061966C8 - 00000008 - 00
Update Mask - 00000000061966D0 - 00000008 - 00
Update Mask - 00000000061966D8 - 00000008 - 00
Update Mask - 00000000061966E0 - 00000008 - 00
Update Mask - 00000000061966E8 - 00000008 - 00
Update Mask - 00000000061966F0 - 00000008 - 00
Update Mask - 00000000061966F8 - 00000008 - 00
Update Mask - 0000000006196700 - 00000008 - 00
Update Mask - 0000000006196708 - 00000008 - 00
Update Mask - 0000000006196710 - 00000008 - 00
Update Mask - 0000000006196718 - 00000008 - 00
Update Mask - 0000000006196720 - 00000008 - 00
Update Mask - 0000000006196728 - 00000008 - 00
Update Mask - 0000000006196730 - 00000008 - 00
Update Mask - 0000000006196738 - 00000008 - 00
Update Mask - 0000000006196740 - 00000008 - 00
Update Mask - 0000000006196748 - 00000008 - 00
Update Mask - 0000000006196750 - 00000008 - 00
Update Mask - 0000000006196758 - 00000008 - 00
Update Mask - 0000000006196760 - 00000008 - 00
Update Mask - 0000000006196768 - 00000008 - 00
Update Mask - 0000000006196770 - 00000008 - 00
Update Mask - 0000000006196778 - 00000008 - 00
Update Mask - 0000000006196780 - 00000008 - 00
Update Mask - 0000000006196788 - 00000008 - 00
Update Mask - 0000000006196790 - 00000008 - 00
Update Mask - 0000000006196798 - 00000008 - 00
Update Mask - 00000000061967A0 - 00000008 - 00
Update Mask - 00000000061967A8 - 00000008 - 00
Update Mask - 00000000061967B0 - 00000008 - 00
Update Mask - 00000000061967B8 - 00000008 - 00
Update Mask - 00000000061967C0 - 00000008 - 00
Update Mask - 00000000061967C8 - 00000008 - 00
Update Mask - 00000000061967D0 - 00000008 - 00
Update Mask - 00000000061967D8 - 00000008 - 00
Update Mask - 00000000061967E0 - 00000008 - 00
Update Mask - 00000000061967E8 - 00000008 - 00
Update Mask - 00000000061967F0 - 00000008 - 00
Update Mask - 00000000061967F8 - 00000008 - 00
Update Mask - 0000000006196800 - 00000008 - 00
Update Mask - 0000000006196808 - 00000008 - 00
Update Mask - 0000000006196810 - 00000008 - 00
Update Mask - 0000000006196818 - 00000008 - 00
Update Mask - 0000000006196820 - 00000008 - 00
Update Mask - 0000000006196828 - 00000008 - 00
Update Mask - 0000000006196830 - 00000008 - 00
Update Mask - 0000000006196838 - 00000008 - 00
Update Mask - 0000000006196840 - 00000008 - 00
Update Mask - 0000000006196848 - 00000008 - 00
Update Mask - 0000000006196850 - 00000008 - 00
Update Mask - 0000000006196858 - 00000008 - 00
Update Mask - 0000000006196860 - 00000008 - 00
Update Mask - 0000000006196868 - 00000008 - 00
Update Mask - 0000000006196870 - 00000008 - 00
Update Mask - 0000000006196878 - 00000008 - 00
Update Mask - 0000000006196880 - 00000008 - 00
Update Mask - 0000000006196888 - 00000008 - 00
Update Mask - 0000000006196890 - 00000008 - 00
Update Mask - 0000000006196898 - 00000008 - 00
Update Mask - 00000000061968A0 - 00000008 - 00
Update Mask - 00000000061968A8 - 00000008 - 00
Update Mask - 00000000061968B0 - 00000008 - 00
Update Mask - 00000000061968B8 - 00000008 - 00
Update Mask - 00000000061968C0 - 00000008 - 00
Update Mask - 0000000006196BE8 - 00000008 - 00ProcessRC: 00000000,00000000ReadContinuous: 00C32D7E,00000258TotalEntries:0000 XfrLen:0258UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|43110081] @LBA=0x00C32D7EOut:
SP Regen FAIL
Any suggestions?
Thanks in advance for any help.
this is very easy to fix now
PostPosted: March 5th, 2019, 3:45
i think firmware are damaged in platter or heads not reading properly
PostPosted: March 5th, 2019, 21:38
@sopon3720@gmail.com, @Dananjaya
Didn't you notice that this thread was just one year old ? :roll:
Users browsing this forum: Google [Bot] and 191 guests
