 Post subject: ST9120317AS
PostPosted: March 3rd, 2018, 12:07
Hello
Drive in topic is locked and terminal is locked as well.
Drive ID as "HP Secure Hard Disk"
FW: HP02SDM5
Terminal output:
Rst 0x08M
(P) SATA Reset
Pass-Through
SeaCOS 3.6 Build 0
?>(1Ah)-Serial Port Disabled
ROM must modified to enable terminal access?
Thanks in advance
 Post subject: Re: ST9120317AS
PostPosted: March 3rd, 2018, 13:25
Spildit wrote:
What is the goal, defeat the lock ?
Not for data recovery. Just to reuse.
Spildit wrote:
It's locked by password or it's just "broken" and you want terminal access or what ?
Locked by password. I want terminal access to unlock.
Thanks for reply.
PostPosted: March 3rd, 2018, 13:56
Spildit wrote:
Check this at your own risk :
http://www.hddoracle.com/viewtopic.php?f=83&t=1406
Read all posts there.
Most likely you will KILL THE DRIVE and DATA WILL BE LOST ANYWAY...
Good luck.
Thank you very much.
But there's no terminal access to enter the command. :)
PostPosted: March 4th, 2018, 4:48
