 Post subject: ST1000LM025
PostPosted: March 17th, 2018, 12:29
Hello
Drive in topic came with 1 defective head(3). After imaging with good heads (0,1,2) I planned to replace heads from several donors but the drive is clicking and it's heads and donor's heads working good on donors. After several attempts looks like the ROM is corrupted and make the drive clicking.
Drive spins fine with donors ROM's. I have a modules copy but no ROM backed up (because of MRT terminal ofcourse)
The question now is how to access user area and complete the image with head (3) without original ROM?
Thanks in advance.
 Post subject: Re: ST1000LM025
PostPosted: March 17th, 2018, 13:00
Hi ,
Well you could use a donor rom and then change 2 modules in sa of patient and you will get user area access .
PostPosted: March 17th, 2018, 13:04
BOVLY001 and MOVLY001?
Am I right here?
Thanks in advance.
PostPosted: March 17th, 2018, 13:18
Am I right here?
Thanks in advance.
Humm,
Yeah ....
PostPosted: March 17th, 2018, 13:20
Thank you very much :good:
PostPosted: March 17th, 2018, 20:37
Spildit wrote:
Are you saying that you can't READ/WRITE ROM on that drive with MRT ?
:shock: :shock: :shock:
Unfortunately, yes.
M8, M9T... etc
MRT cannot r/w those winbond even with MRT programmer.
PostPosted: March 18th, 2018, 11:53
Original heads back and the drive is now return to original state. (ID correctly and shows FW, capacity and SN)
I am confused (ROM wasn't damage at all)
Heads from donors wasn't compatible?
PostPosted: March 18th, 2018, 12:59
Success. :)
Found the matched donor and imaging head(3) now. :)
Case solved.
Thank you Spildit, and Amarbir[CDR-Labs],
:good:
Users browsing this forum: No registered users and 201 guests
