Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Toshiba MQ01ABD100 - Master password changed, locked by
PostPosted: March 23rd, 2018, 20:26
But, read User Area show ABRT Flag, and cant write also nothing, also ABRT flag.
And, maybe you're right, just a question, how to unlock it?
PostPosted: March 23rd, 2018, 20:40
i am saying that the disk is in the write protect state not because of the password, but from the damage in the SA or because of the faulty PCB
I don't know.
It would be possible to try to get access to the terminal.
get out of memory sector S and out of it pull out password
(With the correct password, the minimum should work ATA command 0F2H)
PostPosted: March 23rd, 2018, 20:56
Well, SA(Rom content is ok)
I can Read SMART, And Passport.
Terminal is Blocked,
I dont know how is correct password.
My Toshiba disk reacts identical like Toshiba MQ01ABD032VS Series. Only VS Series not is locked by password, only lock in ROM.
PostPosted: March 23rd, 2018, 21:03
Does the value of smart attributes 4 and 12 (0Ch) change when you turn off/on
PostPosted: March 24th, 2018, 4:30
I've got many drives of this model, but no one with AX1P5E firmware. Check on the label is this the correct FW.
If yes , remove the PCB and conect it to the terminal. After a few minutes the drive will react to VR or VM command and report FW like AXGP5E. This will indicate that the PCB is OK. Use Victoria to read the passport of the drive. Check the Serial Number reported against the SN on the label.
PostPosted: March 24th, 2018, 5:15
Moltke friend yes change this values. And change also power on time attribute. BGman fw on label is ax1p5e but in rom code is axg5e also I see. But everywhere my Toshiba detect with fw ax1p5e. Later attach picture with my disk.
PostPosted: March 24th, 2018, 6:13
Here is label my disk.
PostPosted: March 24th, 2018, 6:22
Ok, but not have PCB G003235C, only G003138 from older ABD and ABD Vs Series.
I can resolder ROM chip to other PCB like G003138 and see reacts, if block is in ROM or Security Sector.
PostPosted: March 24th, 2018, 6:35
I test with G003138 from older ABD and Spindel running but clicking of course not solder correct rom only test.
Try it, and this will exclude if block is in ROM, or Sector Security.
PostPosted: March 24th, 2018, 7:07
Spildit wrote:
If the drive accpts the SUPER ON you shouldn't be able to retrieve S.M.A.R.T. when SUPER ON is .... ON.
But i still can watch Smart, Super ON feature momentally show ABRT/ERR flags.
test react from PCB G3138A, and this is not compatibile with my original ROM, Disk is in BSY State and nothing else.
PostPosted: March 24th, 2018, 7:37
This in this maybe problem, poor i'm and spend 200 polish zloty to other disk this for me is a lot :(
PostPosted: March 24th, 2018, 8:38
I test also react the same PCB without disk, and also test same pcb without disk(old ABD series)
and my insights are
That same pcb is very slow, and if is RDY/DSC state, this only need to click detect disk, this active flag DRQ.
And in both pcb's are the same react.
PostPosted: March 24th, 2018, 8:41
Spildit wrote:
Drive rejects the SUPER ON with ERROR and ABORT. You can't use the 8E to re-create S xx,01 (...) 8E if the drive did already reject the SUPER ON.
zu does not use 8e, and super-on's has more than one.
The pointer to the SA in different rom is not required to match, so the permutation
the pcb may not give anything.
PostPosted: March 24th, 2018, 8:50
Ok, But as we can see, Zu can not handle this disc, i can attach screen.
PostPosted: March 24th, 2018, 9:05
Why did the ZU work for 30 minutes?
And you can always take advantage of other programs that can.
PostPosted: March 24th, 2018, 9:36
Spildit wrote:
The drive is rejecting the Super ON. Other programs are not unlocking the drive as well.
Well, that's bad luck. Write technical support for these programs.
PostPosted: March 24th, 2018, 9:40
Maybe Toshiba has changed the SuperOn command for its new drives. :shock:
In this case you have to use the COM port terminal to set factory mode and then to try clear PWD.
It would be nice if somebody having such drive check its response to standard SuperOn command.
PostPosted: March 24th, 2018, 9:44
Well, this on me, also unlock work from old ABD series in FW AX001U, but this is from 2011year.
And this disk have new FW Type, and on 100% have diffrent VSC command to unlock SuperOn.
Yes, Terminal not work.
PostPosted: March 24th, 2018, 9:51
Do you want to try a very stupid thing ?
Check with Hitachi ARM SeDiv tool and see if the drive accepts the Super On.
This is silly but ..... just to be sure.
No problem, i can test.
PostPosted: March 24th, 2018, 10:07
Spildit wrote:
I did unlock several drives of the same model - MQ01ABD100 - using the standard VSCs and they did work ...
I'm not talking about the model, I'm talking about the FW revision. Can't you make the differance?
ALL Toshiba drives have terminal support! Even if you remove the Flash chip !
Sometimes it takes a few minutes to get ready, but eventually they do respond!!!
Two reasons for slow response :
1. Non-native PCB
2. Too many deffects in the lists.
Users browsing this forum: Google [Bot] and 250 guests
