Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Toshiba MQ01ABD100 - Master password changed, locked by
PostPosted: March 24th, 2018, 10:10
BGman wrote:
ALL Toshiba drives have terminal support! Even if you remove the Flash chip !
Sometimes it takes a few minutes to get ready, but eventually they do respond!!!
No.
On some models/FW
The terminal should be specially unlocked.
PostPosted: March 24th, 2018, 10:12
Yes, Agree, but in locked Toshibas, terminal not respond, i have Toshiba ABD VS Series with locked rom and Terminal not respond.
Slow respond is when connect same PCB. in Disk this very fast detect.
But Still Active PWD flag.
Spildit Test this, ARM Hitachi and Say to me that this toshiba is not ARM type, and Super ON ERROR -> not have option to enable this state.
PostPosted: March 24th, 2018, 11:11
You mean, that i pach rom from Dump, or you mean that i have patch rom from VS Toshiba?
I want to know if I understood.
PostPosted: March 24th, 2018, 11:31
Ok, but we do not know yet what is Firmware Oleg, if is AX00XX or AXP1E etc.etc.
If AX00 this Rom Code not work on my Toshiba.
I Find Infos, that This Toshiba with FW AX1P5E Mounted is in Lenovo laptops, maybe password are make is under concrets series hmm?
And connect This HDD under my PC and even not ask me about password, only goes on.
PostPosted: March 28th, 2018, 10:14
Case Solved, send to client not unlocked Disk.
PostPosted: March 28th, 2018, 16:10
Yes, because not found compatibile ROM code, and from ROM AX00xx my disk not work.
Users browsing this forum: No registered users and 53 guests
