 Post subject: Zeus smart hot swap -- standby mode
PostPosted: March 28th, 2018, 10:49
Haven't worked with WD Zeus family in quite some time.
We're working on a case that needed new heads. Created a smart hot swap donor with a very compatible drive (its partner in a RAID assembly).
I can't get the smart hot swap donor to stay in standby mode. After execution, it waits a few seconds; goes busy; and spins up (using PC3K).
Anyone recall how to force this into a true standby mode?
THX
http://www.datasaversllc.com
 Post subject: Re: Zeus smart hot swap -- standby mode
PostPosted: March 28th, 2018, 11:04
Doesn't changing head map in RAM work for you on this one? That's what I usually do.
PostPosted: March 28th, 2018, 12:55
Sometimes the "Spin down" option works rather than the "Stand By".
PostPosted: March 28th, 2018, 12:59
If memory serves me correctly, I used to either do a fresh power off and on before doing the spindown or maybe it was a soft reset. But, I do recall that it was a PITA.
PostPosted: March 28th, 2018, 14:34
Thanks for the suggestions.
I used to do the head map change, and for some reason I didn't try it (maybe because it was multiple steps involving the ROM).
The spin down command did it, but I had to find it (it's among the commands on the right side, which I don't frequent). This seemed to be the path of least resistance.
Much obliged.
PostPosted: March 28th, 2018, 17:15
yes, techno spin down works for some families where stand by did't work.
Data Recovery Pakistan
PostPosted: March 29th, 2018, 13:39
Much obliged.
You are welcome. I know.. I scratched my head a while too.. Glad it worked.
Users browsing this forum: Google [Bot], gps31 and 256 guests
