 Post subject: Reballing BGA?
PostPosted: March 27th, 2018, 9:34
This is most likely a stupid question, but since there's no manual anywhere, I have to ask: is it required to reball the BGA-chips prior using them in the adapters? (More specifically, the eMMC-adapters)
I got hold of two scrapped Android-phones, both using eMMC, but nothing shows up when I connect them to the adapter hooked up to the SD-port. There is ofcourse a possibility I damaged the chips whilst removing them using the IR-station, but other than that I fail hard to understand why nothing happens with the adapters.
 Post subject: Re: Reballing BGA?
PostPosted: March 27th, 2018, 9:39
No need. Use without reball. Just clean the chip very good. If you not clean enough it could be not recognized. Also there is a chance that you damage the chip.
PostPosted: March 27th, 2018, 9:46
Thanks. I'm aware of that the chips could have been damaged, but I have to try everything I can before scrapping them.
It's way harder than I thought to get dead devices to practice on. People are very very unwilling to donate their dead phones / pen drives etc, even if I assure them I only want to practise and learn on them. I wish I had a truckload of dead devices. These two phones are the first one I got hold of since november last year. Too long time between the cases = I forget everything I learned last time, and have to start all over again.
And that sucks.
PostPosted: March 28th, 2018, 15:48
What exactly eMMC you got (Raster/Pitch)
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
PostPosted: March 29th, 2018, 13:27
Agree And Disagree ,
Depends on The Emmc Reader The Guy Has ,Some Need The Balls Most Do Not
PostPosted: March 29th, 2018, 17:16
The good one no need.
PostPosted: March 29th, 2018, 18:04
It’s true, good adapter/reader doesn’t need Re-balling
