 Post subject: Problems with a hdd i see only .dat files
PostPosted: March 27th, 2018, 7:44
Hi, I have a problem with an old hdd it seems that it show's only .dat files and all the folders are dirXXXX , anyone has any idea how can i recover my data from it, and also when i plug it takes like 40 sec to connect and there are some wired sounds inside until connects. thank you
File comment: this is what's inside of the each folder
File comment: these are the dir folders
File comment: this is the hdd
 Post subject: Re: Problems with a hdd i see only .dat files
PostPosted: March 27th, 2018, 10:22
How do you think it got like that? And what should have the file structure been like?
PostPosted: April 2nd, 2018, 1:17
What kind of partition is this ? Was this drive used inside a computer, or inside a standalone video recorder ?
What do those .dat files look like if you open them with an hexadecimal editor ? (HxD is a good free one.)
Did you check the SMART informations, in an effort to untangle the wiredness ?
PostPosted: April 2nd, 2018, 6:15
Sir ,
is this hdd in a cctv ?
Users browsing this forum: Google [Bot] and 68 guests
